Question about Canon Office Equipment & Supplies
Paper is not feeding as it is too cold or damp. Is it possible to install any sort of heating element within the machine to keep paper dry and moving. IRC2880
  • 37 Answers
No, however you can try to put large packs of silica in the drawer to help absorb the moisture. If the paper is curling you may try fliping it over in the drawer. There are service settings to help with this as well. Those must be done by a tech as you can screw up your machine if it is done wrong.
Posted on Jul 28, 2009
Do you know if it's a hot or cold feed at inlet
Hi Charles
The traditional method of supply was using hot water for filling. However, it is possible to save money on some machines by hooking up to cold water as the element in the dishwasher uses less power than your water heater. Unfortunately, some manufacturers still require using hot water for filling. You'll need to check your manual to see if this is the case. Here's a link to This Old House explaining dishwasher installation.
Hope this helps
-Steve
How to Install Dishwasher
Mar 04, 2015 | Dishwashers
Washer dryer not drying properly
the heating element of you dryer broken already
Feb 03, 2014 | Indesit Washing Machines
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Drying clothes are cold and not getting dry
Bad heating element or thermal coupling. You need to take back of dryer off, unplug first. Then check with a tester all thermal coupling and heating element. You won't know until dryer is troubleshooted.
Jun 01, 2010 | Kenmore 63942 Dryer
Paper jam
Carefully remove the paper tray and the paper. The sheet(s) that are stuck can then be firmly but gently pulled backwards out of the feed input.
To avoid the problem check these possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Jul 23, 2008 | Lexmark X7170 All-In-One InkJet Printer
Paper jams every time I try to print something
2 possible solutions.
Good Luck
Carrieone
Jul 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Too Much Paper
Good Luck
Carrieone
Apr 02, 2008 | HP Photosmart 7450 InkJet Printer
Machine won't draw the paper in to send the fax
Technically, your machine is jammed. The paper is jamming as it exits the feed area, and enters the machine. Not being specifically familiar with that model, but rather based on experience with other simular machines with like problems, I would say you should look for 3 possible causes... Most machines have, shortly into the paper path, and generally in the area you're indicating, some sort of sensor switch, whether it be photo-electric, or a mechanically activated toggle, that senses and registers the lead edge of the paper so the machine knows it did feed. This switch could be knocked out of place, or simply dirty, and not sensing the lead edge of the paper within a certain period of time after the machine registers the feed had been actuated. A second possible cause would be (and you may be able to visually verify this) is that usually, in these types of machines, there is some sort of pressure or "retard" pad/roller in conjunction with the feed roller. If this isn't working right, the machine may be feeding more than one sheet at a time, and becoming jammed in the paper path path area due to "thickness". A third possible issue could be an unremoved scrap of paper from a previous jam (or a staple/paperclip/piece of rubber-band/or any other foriegn object, as I've seen them all) still remaining in a thin and obscure position of the paper path blocking the paper's progress to the afformentioned switch. Those are the most likely, but probably not the only possible, causes of the problem you are exoeriencing.
Jan 07, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
48 people viewed this question
old marine
old marine
