Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have my l7 solo baric on series mode they sund
I have my l7 15'solo baric on series mode they sound good but if i put them in paralel mode would they soud louder n the bass hitt harder?.my lows is a mtx thunder1500 1ch amp d block..
  • 655 Answers
Hello rigo11785,
The MTX Thunder 1501D is stable at 1ohm and outputs 1,500 watts RMS into that impedance. An L7 with 2ohm DVC's would present a 1ohm load if wired in parallel and would allow the amp to produce more power than into the 4ohm series load. The problem is that the L7's maximum power handling rating is only 1,000 watts RMS, so if you wire the coils in parallel, you'll very likely overdrive the sub and perhaps damage it. Now, if you bought another L7 and ran the voice coils in series and the subs in parallel, that would be a 2ohm load and well within their power handling capability.
With that amp and sub, I'd recommend leaving the voice coils in series.
Hope this helps.
Posted on Jul 28, 2009
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
I have three kicker l7 15 at 2ohm and a kicker zx2500.1 amp what be da best wiring setup
there are to ways you can hook these up you can do series or parallel.this will give you an idea. Here is a link that will help you alot http://kicker.com/resistance_formulasget back with me ?
Sep 23, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a kicker 15 inch L7 solo baric and the rubber piece around the plastic part of the center of the sub has come apart from the outside black ring. how can i fix this?
You can purchase a silicone sealant set, specifically for speakers. Its quite easy to use. Ebay has alot of them and they are relatively cheap.
May 03, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
I wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Oct 13, 2009 | Car Audio & Video
Whats the best settings for a 2 ohm solo baric 15
settings are all about what amp and box u got. tell what setting your talking about.
Apr 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
150 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
