Question about JVC AV-65WP55 65" Rear Projection HDTV-Ready Television
Jvc i art av 36f475: no sound
When we turn on our jvc i art av 36f475 TV, all we hear is static-- the sound does not work at all. We checked to see that all of the inputs were plugged in and they are. This just started happening and we haven't changed anything. This is also true when we try to play Wii.
  • 979 Answers
Good Day sir/maam, my guess are several, lets start at the common ones, make sure that the AV cables are good. you can try swapping cables to make sure. If possible try the cables on other units such as any DVD player. There is a possibility that the sound jack, is bad, try to vibrate the plugged cable, and see if the sound goes back if it does, you need to solder the terminals. Worse is the Amplifier section of the TV. does the TV sound normal on broadcast? check the volume, mute. or the TV setup. hope this helps. if you have additional info please feel free to ask again, let me know any progress. thanks
Posted on Jul 28, 2009
I have a GE remote and an I'Art JVC tv, cannot get remote to work.
Setup codes for JVC with GE remote control are:
0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Jul 29, 2012 | JVC AV-27020 TV
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Blank/Black Screen, Sound/Audio is Static/Noise
It sounds like the Main board has gone out, but I would still check out the Power board also.
Mar 21, 2009 | JVC AV-27020 TV
Loud noise when I turn on tv
Good day.
There might be some leakage along the regulator section of your unit. try to check for the leakages along the filer capacitors likewise.
Regards,
chris
Jul 22, 2008 | JVC AV-32260 32" TV
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
Tv picture is black, sound is fine
Sorry, no easy answer here. On an older set this would be espected and not worth repairing, but you should take this to a TV shop for troubleshooting. Most likely culprit is the flyback transformer and/or the horizontal deflection.
Hope Ya Fix It.
Jan 31, 2008 | JVC AV-27F702 27" TV
JVC AV-27820 27
shorted components causes continuous ticking/clicking sound from inside the set! it would really need a shop visit since you have no picture display! if you could trust the service person then it could be worth sending it to a shop!
Dec 06, 2007 | JVC AV-27820 27" TV
JVC AV-65WP55 65" Rear Projection HDTV-Ready Television Logo
198 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
