Low toner light
I have the above printer which has turned on its orange light in toner, hence i cant print. Even thought i have blocked the sensor lights with black tape, it still doesnt print. The Toner has been filled with 100g of recommended ink amount but still it doesnt print.
  • al555 Jul 28, 2009
    The Model is
    Fuji Xerox Docuprint 203a. Thanks
  • Anonymous May 11, 2010
    model please
  • 3 Answers
Check the tonner placement is correct
Posted on Jul 28, 2009
Brother 5370 toner light stays on continuously
if you take the toner cart out and look on the right hand side of it, you will notice a little round window, this window lines up with a sensor inside the printer which looks to this window to reflect back off the toner inside (toner still available)
When the toner gets low enough the sensor does not get a signal back and reports that its out of toner hence the red light.....here's the trick.... if you put a small piece of BLACK tape over the window your printer will continue to print until it completely runs out of toner (several 100 more pages)
Jul 12, 2011 | Brother HL-5370DWT Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
How do I change the toner density on the push button display when it is locked with an * We have low or a feint print out of the fine print on the print settings print out test sheets. I have cleaned all...
A new laser could help, but you should make sure the toner save is turned off, it makes toner last longer by making light prints. Toner save is set in printer properties in the control panel
Sep 10, 2009 | Brother HL-5240 Laser Printer
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
How can I see how much toner/ink is left over?
You can get the user guide here: http://h10032.www1.hp.com/ctg/Manual/c00264334.pdf
This should help you determine how to tell how much toner is left.
Dec 11, 2008 | HP LaserJet 1020 Printer
E120 won't print. Orange toner light is on - but the toner is nearly new ...
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
Sep 19, 2008 | Lexmark E120n Laser Printer
Low toner
Toner fully try in Developer unit wait same time for toner adding and press start contuies 10 copies it will slove the problem.or clean toner level sensor
Jul 24, 2008 | Toshiba e-Studio65 Copier
Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
May 30, 2008 | Brother HL-5240 Laser Printer
204 people viewed this question
jasbo
jasbo
