Question about Grilling
Traeger temp controller reads 510,on the digital read out. grill not working!
    Top Expert:
  • Grilling Master
  • 8,861 Answers
Replace temp sensor
Posted on Sep 11, 2017
3 Suggested Answers
reg501
  • 413 Answers
SOURCE: Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Posted on Jun 08, 2008
  • 332 Answers
SOURCE: I have a Traeger Executive 100 with a digital
Call Traeger direct.
You have a bad control unit
Mike Treager is really good about replacing anything that goes wrong
Posted on Mar 07, 2010
Why does my Traeger Smoker not hold temperature.
The Traeger has no thermostat, it works by approximating how often the auger needs to push pellets into the fire box. If the temperature is within 20 degrees, Traeger considers that within range. If you live somewhere with extreme weather, this could affect your Traeger's performance. If it's cold outside, set the Traeger to a higher temp (or get one of their insulating blankets). If it's hot, set the Traeger lower. I hope this helps.
Dec 31, 2017 | Grilling
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
On smoke setting my temp goes up over 300 degrees
Traeger suggests realignment of the augur for grills that are not getting hot enough. I wonder if this might be the same solution for grills that are getting too hot.
Here's their solution which I copied from the Traeger website at http://www.traegergrills.com/.
I've been noticing that my grill temperature keeps dropping lower. What is the problem?
You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
You might want to contact Traeger at their website to verify that this is a solution for overheating. In the above case, the improperly aligned augur was not dropping enough pellets in the firepot. In your case, it sounds like it may be dropping too many. This sounds like a routine maintenance thing that ought to be done periodically anyway.
May 12, 2014 | Traeger Industries Grilling
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I turned off my grill yesterday and it kept on smoking. There seems to have been a fire at the base of the pellet bin. How can I fix this fast? I have three events beginning on Saturday, where my...
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Jun 30, 2011 | Traeger Industries BBQ125 All-in-One Grill...
Have a traeger grill and while cooking it gave me an error message on the digital thermostat. what could be the problem
So I got a ERR on my treager it end up being the controller thank god had a old one to test it good to know
Nov 20, 2010 | Traeger Industries BBQ070 All-in-One Grill...
I'm getting an "Err" message on my digital temperature reading. The grill starts up but then shuts down when the "Err" message comes up.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
Aug 13, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Grilling Logo
317 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
