Question about Samsung RS2578BB Side by Side Refrigerator
Frigidaire side-by-side stopped working
Bought a SS frigidaire side-by-side a little over a year ago, and we found today all our freezer food thawed out and the fridge and freezer at 50 degrees each. (There was no ice glaze or frost on anything.) Three days ago our street had a power outage (due to power company's equipment failure.) Then yesterday we had a bad thunderstorm and although power did not go out, lightning struck so close by that we had some type of power surge which threw a breaker in part of the house (not the kitchen though.) Could this be something caused by the lightning, or by the power outage? We unplugged it, then plugged it back in, but it still did the same thing (it sounds like the motor/fan comes on and turns back off within about 8 seconds.) Thanks for any advice!
    Scholar:
  • 117 Answers
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Posted on Jul 28, 2009
FRS26KF6EMK FRIGIDAIRE SS SIDE BY SIDE,stopped cooling,why?
There are many reasons for these symptoms. Feel the compressor top, is it too hot to keep your hand there? Look into the back of the freezer and tell me what type of frost pattern is on the rear wall? If the compressor won't start it could be because of a defective
Run Capacitor 5304464438
Start Device 241707712 APPLIANCE 911
Freon leaks or failed compressor can also cause the same symptoms
May 23, 2016 | Frigidaire Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Our freezer just apparently stopped freezing, but the refrigerator still works. It's a Frigidaire Gallery just purchased a few months ago. Suggestions?
Hello, Thank You for using FixYa. I will be helping you today.All the cooling comes from the freezer side. So if the fresh food side is working then the freezer is only producing enough to allow the temps to be around 38 degrees. Do you notice any frost on the freezer back wall? Its possible its a defrost issue.Can you hear the fan Running in the freezer when the compressor is on? If these all seem fine then I would say you have a sealed system issue. Either a leak or bad compressor. Since its only a few months old call for factory service it should have a one year warranty on parts and labor.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Samsung RS2578BB Side by Side Refrigerator Logo
374 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
