Question about Sharp R-320H Microwave Oven
Sharp r-320F digital time display
The digitlal clock reading and countdown area is totally gone out on my micro. Everything else works fine but there are no numbers or anything on it. Please let me know if this is fixable as you really need to see if you have the right settings. thanks
  • Anonymous Feb 14, 2008
    Same problem after about 1 year of use! Bought this oven in Feb. 2003 and it died in Jan 2008. Very disgusted with this appliance, and of course the warranty is outdated! Any thoughts on what to do?
  • Sharp Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
We have full details and *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our
listing here on FixYa:
Posted on Nov 22, 2007
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Can't read display
The display is failing, the keypad control board must be replaced to remedy the situation.
Apr 22, 2012 | Sharp R-1610 Microwave Oven
I also have a Sharp Carousel Microwave oven model # R-409AK in which the clock/ timer digital display has become faint and can not read the time. The microwave part works fine otherwise. What part do I...
It is a display panel you require and you should be able to get a manual at the same time.
Hope it is helpfull
Feb 27, 2011 | Sharp R-319FW Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Sharp Microwave Display intermittently working. Most of the time can't see time or countdown.
Only way this can repaired is to replace the whole display. If the unit is still under warranty take it to your local Sharp Service Center.
Otherwise, it is more than likely beyond economical repair. If you can live with it as is and just use it for short reheating you'll be fine, but the display will not improve. It can also be a safety issue as you could accidentally put in too great a time and burn foo, or even yourself with the contents of the microwave.
Mar 28, 2009 | Sharp Microwave Ovens
Display not lit up
Seems like the display panel went bad. You can check for sure by unplagging the unit for 45 seconds and plugging it back in. If still no display order a new display panel.
Please rate if you are satisfied
Feb 12, 2009 | Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Sharp Model R-320F - The Time Display is not readable. Only sporatic lightings appear.
We repair these for customers nationwide with our guaranteed $39.95 service.
William E. Miller
Aug 13, 2008 | Sharp Microwave Ovens
Sounds like it's running but no heat
Those symptoms are what I would expect when the controller or keypad gets wet. Tipping it is not an issue, unless that allowed the water to run into the controls more than just the wet soapy washcloth did. You may get lucky - it may dry out by itself in a few days. If not, and if careful targeting drying doesn't fix it, it will need a new keypad or controller.
May 23, 2007 | KitchenAid KCMS145J Microwave Oven
Sharp R-320H Microwave Oven Logo
258 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
