Question about KitchenAid Refrigerators
Kitchenaid superba ksra22fkss00 side by side fridge. The freezer temperature too cold.
It's set at 0F but the freezer is at -15Fto -20F and the over temperature alarm keeps tripping. Diagnostic indicator #1 shows pass for the freezer thermistor. What could cause this?
    Scholar:
    New Friend:
  • 67 Answers
Even though the freezer thermistor passes the test, it's bad. The test only sees if the thermistor is open circuit or grounded. These thermistors can send bad information to board. Replace the freezer thermistor and I think that will solve your issue. Good Luck
Posted on Oct 20, 2017
the dr
  • 447 Answers
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Posted on Dec 27, 2007
dcp2
  • 63 Answers
SOURCE: Kitchenaide Superba Side by Side Refridgerator-alarm keeps going off
Its called a Manometer. You shut the gas off and unscrew a alen/ hex head screw in the outlet side of the regulator. Screw the end of the manometer in then turn the gas on. turn the temperature up and down and the gas pressure should go up and down with the flame.
Posted on Jan 29, 2008
  • 3382 Answers
SOURCE: Freezer below temperature
If this is just a freezer then the likely problem is a failed thermostat. If it is a combo then check the refrigerator settings and possibly a door leak in the refrigerator. The refrigeration is shared between both sides and to my knowledge never 100% on either side.
Good Luck,
Gilsh
Posted on Nov 29, 2009
heatman101
  • 43501 Answers
SOURCE: side by side kitchenaid freezer temperature indicator.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
shastalaker7
  • 1515 Answers
SOURCE: RE: Frigidaire upright freezer. Where
Hi, not knowing the model number, I would say that if you can't see the reset button in or around the perimeter of the door, as the thermostat is located high up toward the top of the thermostatic expansion valve, it doesn't have the alarm button on it. What I would do, is locate the alarm buzzer, unplug it and clip the wire going to it. No harm done, and you can always reconnect the alarm. For the alarm to be going off when the temperature is good, the thermostat is out of calibration. If its freezing good, just clip the wire, no harm done.
Sincerely,Shastalaker7
A/C, Heating, & Commercial Refrigeration repair
Posted on Jan 06, 2011
My fridge seems to be working but not cold is on coldest setting fridge part 50F freezer 20F
You probably need to defrost the whole unit, and raise the thermostat temperature
Jul 04, 2010 | GALAXY Microsystems 25.4 cu. ft....
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Freezer below temperature. Set to 0F and is at -20F.
Good Luck,
Gilsh
Nov 28, 2009 | Sub-Zero 601R
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge freezer double door top fridge bottom freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING
Allowing.. MORE AIR.. to refrigertor side
Oct 24, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
75 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
