Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
Oven will not turn on (by 4 users)
posted by odie7770 on Nov 22, 2007
followed instructions on activating oven, but it will not heat.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Feb 08, 2008
my oven temp. will not work but turning on the bake button gets it too hot when i set the thermostat it turns off
Comment by Guest, posted on Dec 16, 2007
I have a sears slide-in electric range.All of a sudden the oven and the broiler will not work. The burners, timer and the clock work. I had the elements for the broiler and oven checked and they are fine. What could it be?
Comment by kubadoo, posted on Dec 16, 2007
oven element burned out. I didn't know it was hard wired in the back. I pulled it out and got a large burn-out like fire works that shot out. Oops. Was told I should not have done that. Since then had someone take the element out, wires burned on back. Also since the fireworks, the top burners also quit. New element came in. Someone installed new element but still nothing works. Where are the fuses located or could I have burned everything out with the firework like display I had ?
Solution #1
posted on Aug 19, 2008
Not Rated (0)
elan2
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Where are the fuses please?
I see no lights or display.
Gas can be released, however cliker / ignighter fails.
What can I do to repair this please?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Oven will not turn on:
I don't want to Accept this solution
Provided by KENMORE STAFF
Solution #2
posted on Nov 22, 2007
Not Rated (0)
super tech
STAFF
Rank:Guru Guru
Rating: 87%, 147 votes
could be fuses, timer set for auto cook,bad element or bad controlor a wire burnt off
Thank You!
Can you Help with these Kitchen Ranges problems?
Whirlpool GS460 Gas Kitchen Range
Initially began with no "beep" when turning on,...
Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
I have purchased a new oven and had it fitted, it was from...
Kenmore 75503 Stainless Steel Dual Fuel...
Since you can't self clean the racks, how do you clean...
Kitchen Ranges
I have a Thermador cooktop model TCT or TGT 45,...
Viking VDSC365-6B Dual Fuel (Electric and...
Viking VGIC3084BSS
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
