Question about Maytag MSD2656G Side by Side Refrigerator
Water is leaking from under GE side by side from time to time.
Can not find where this water coming from. It is not continuously. From time to time there will be a puddle under the fridge
    Scholar:
  • 117 Answers
More than likely the water is coming from the water produced from the defrost cycle. Ordinarily the water is piped through the back of the frig to a tray next to the compressor. The pipe may be out of place or crack in tray? Hope this helps
Posted on Jul 28, 2009
  • 24 Answers
This _may_ be normal behaviour. When the freezer defrost element is heating, ice that melts off of the evaporator coils in the freezer will drain out of a small opening at the back of the freezer compartment and into a catch pan under the refrigerator. If that pan has other debris - cat hair, napkins, etc - the water may overflow the pan onto the floor.
Get behind the fridge, remove the bottom panel (at least that is how I can access it on my GE side-by-side), and see what you can see.
While you are back there, it is a good idea to clean the dust from the condenser coil, or use a shop vac to blow the dust from the coil.
Remember your electrical safety and unplug the fridge first, and be careful what you touch. I assume the compressor uses a large start capacitor that could still be energized even with the fridge unpluged.
4 Suggested Answers
Bgillespie
  • 89 Answers
SOURCE: water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Posted on Dec 02, 2008
  • 235 Answers
SOURCE: Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Posted on Jul 12, 2009
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
12 yr old ge refrigerator leaks water on kitchen floor occassiona
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak from under fridge when water dispenser is used
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag MSD2656G Side by Side Refrigerator Logo
217 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
