Question about Maytag Dryers
My maytag Dependable Care Quiet Plus 2 /gas dryier
Makes a Loud Thumping/ Squeeking/ Grinding type sound when i turn it on! and will i be able to fix this myself or do i need a repair man?
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Posted on Sep 03, 2011
I have a Maytag Dependable Care Plus/Heavy Duty dryer (LDE8704ACE) that has served me well with no problems for more than 16 years. Yesterday, it started making a thumping noise that sounded like a huge...
hi look at the lower bottom of front there are 2 screws pull from bottom hing out watch for door switch wires swing front around. look in side top left and right corners 2 5/16 or 3/8 bolts pull them out. lift top up you will see screws that hold fin. oh turn power off hope this helps jim
Oct 13, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
My Maytag washer fill too slowly
There's a little screen at one end of the inlet hose that will clog up; remove that and clean it. Don't forget to reinstall it. You can buy a replacement at the hardware store; take the old one along, there are a lot of different sizes.
Jun 09, 2009 | Maytag Dependable Care LAT9706
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Dryers Logo
761 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
