Question about Kitchen Ranges
I order a new burn switch, i forgot the wire set up. i need the wiring diagram
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
Look on and inside the unit there should be a schematic diagram for the unit that will show you the wiring diagram
Posted on Aug 23, 2009
Power windows don't work
I can provide wiring diagrams and locations however I need to know what size motor you have. The 2.0L or 2.5L.
Thanks in advance
Jul 04, 2008 | 1989 Toyota Camry
How do you find a wiring diagram for a delonghi magnifica coffee maker to rewire the steam unit
You should tell what model machine you have. It's not a problem to find a wiring diagram in service manual.
Feb 26, 2015 | DeLonghi Magnifica Coffee Makers &...
Alternator burned wire harness all wiresburned
Here is what the wiring diagram shows for 1996-2000
Feb 09, 2014 | 2000 Honda Odyssey
Had to replace new pressure switch on a karcher k6.50 pressure washer ,but I forgot which wire goes to which terminals.
if its two wire it shouldnt matter... if it's multi wire then you are going to need a proper wiring diagram from them
Oct 13, 2013 | Electric 1600 Psi Pressure Washer
I have a set of hand controls for a 95-06 Harley with no diagram how Do I figure out witch wire from the switches go were
If you're simply replacing the controls with other controls, the color coding of the wires should be the same. Simply unplug the old wire from the plug and insert the same color wire from the new set. Now, if you're trying to install a later set of switches on an earlier model bike, you need a wiring diagram of BOTH the new switches and the old bike so you can figure out the color codes on the wires.
Good Luck
Steve
Mar 02, 2011 | Harley Davidson XL 1200 C Sportster Custom...
1997 Chevy Lumina, I replaced the passenger side power window motor due to the factory one failing, The person before me cut all the wires going to the motor and toggle switch in their attempts to fix /...
There is a wiring harness on hinge side of passenger door correct, take a look at the wiring colors. Hope you can read it. At the window switch, the outside wire on either side is voltage or ground depending on which direction, up or down, reversing motor. You don't need the window switch for testing, you should be able to operate from driver door master switch. If you get the wires reversed, the only thing that will happen is, up will be down and down will be up, if that happens, reverse the wires. Just my opinion.
At the window switch, top middle wire is lockout, so only the driver can operate the windows.
Apr 26, 2017 | 1997 Chevrolet Lumina
All the insulation on my map sensor pigtail wires has burned off. A friend of my cut the wires near the computer and I bought a new pigtail... but the wires on the new pigtail are all white and I need to...
Okay here we go, there are three wires from the map sensor, if you look at the sensor there are letters stamped on the plug area, theres an A,B,and C the wires start from the sensor as orange/blk to terminal A then lite green wire to terminal B and last is gray wire to terminal C . im not sure what wires your freind cut but there only one at computer for map sensor and thats the signal wire, all slots at computer are numbered the signal wire is light green and connects to slot #25. heres a diagram for all wires to computer you will need to locate the wire in order to connect them back, this is not hard find the open slots and check diagram for wire color, hope this helps, good luck.3b58cfd.gif
Oct 27, 2010 | 1998 Oldsmobile Achieva
Replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
Jan 22, 2009 | Kitchen Ranges
Sparkplug wiring for 1995 chevy suburban
It should say on the intake if noti think the right side is 1 3 5 7 left is 2 4 6 8 if it back fires or dont start switch it around .
Oct 20, 2008 | 1989 Chevrolet C1500
Kitchen Ranges Logo
224 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
