Question about Nintendo Pokemon Diamond for DS
Dog chewed on ds game cartridge and we would like to get the info off of it. The board is slightly bent at the contacts and there are some toothmarks just below. Would it be possible to get the game information from it?
Try to contact Nintendo's Repair Center, they could tell you what to do or maybe they could try to retrieve the data if it's not too much damaged. If the game works but the data is inaccessible (a message saying so would appear before the title screen), the EEPROM (the memory of the card) might be disconnected of the card or broken. Physical harm to the DS card could also corrupt the data. If so, the game will warn you with this message ''The (game title) data is corrupted and will be deleted'' and the game's data will be unfortunately deleted.
Posted on Jan 11, 2010
    Problem Solver:
  • 9 Answers
If u can get to the menu like options start game internet the title screen and if u have a wii with pokemon ranch u can put your pokemon on it
Posted on Jul 29, 2009
I bought a brand new DS lite online, it functions perfectly when switched on, but when I insert a game card it immediately switches itself off. if I insert the game card before turning the DS on, then it...
I had just repaired two of these with the same problems, and ran into two different solutions! First solution is too check with a little flash light inside the game cartridge area where you insert the game for bent pins that may contact each other when the game is inserted, the solution is to take apart and repair the bent pins by straightening them out, or buy a new cartridge holder from ebay to solder on the board. This fixes no read and shut down of ds, and is a permanent fix, until someone jams a cartridge back in and bends the pins again.
The other fix, is to buy a new motherboard I found that one had a circuit malfunction which caused this issue.
Most likely and a lot of times it is in fact bent pins causing this because when inserting the game into the cartridge area over and over with force or putting it in backwards and forcing it by someone that doesn't know any better will create the problem and that leaves you two options I stated above: If you can fix the bent pins you might have success, if you can solder, you can replace the game cartridge on the motherboard, and or replace motherboard if that failed. If you don't do none of these you have the option to get it repaired, sell it back on eBay.
The pins are fragile and can be bent in ways not repairable in that case you would safe time and effort to buy a game cartridge on line, cheap few bucks, and solder it onto motherboard to fix your issue.
Just look for game cartridge slot reader for your type of ds on eBay! Good Luck!
Oct 24, 2013 | Nintendo DS Console
The top screen of our DS is frozen white and blotcy.
Well that can mean only one thing and that is that the screen is damaged either from being dropped or water damage or from being thrown or chewed on which dogs are famous for chewing on things. So what you need to do is either get the screen replaced through the manufacturer or you can go the cheaper route and buy a new DS.
Mar 04, 2010 | Nintendo DS Console
My Nintendo DS does not work right. It says there
Have a look down the game slot for any bent or broken pins if not the slot 1 game socket is not holding the game cartridge tight enough to the pins to make a good connection. there is a quick fix for this that has worked for me, only if you are confident enough to open up the ds, by pressing down hard enough to make a slight dent in metal peice on the logic board, press down the bottom corners and the middle with a small screw driver and that should cure the problem. good luck <tell me how it goes>
Jan 08, 2010 | Nintendo DS Lite Red Console
Help! My pokemon platinum game got chewed up!
I think that the game may just have to be buried as, by looking at the phrase that came up, Ithink that your dog may have damaged the save file.
Nov 16, 2009 | Pokemon Video Game Consoles & Games
Game are not working when inserted into the console
The slot 1 on the board is faulty replace it look down where the cartridge goes in good light and see if the pins are bent look hard they are hard to see sometimes you can straighten them (sometimes) also look at the cartridge and tru and clean the copper pins (extra hard toothbrush)
Feb 23, 2009 | Nintendo DS Lite Console
Nintendo ds lite charger
just buy a new one i use 3rd and 1st party work the same keep it away from your dog
Jan 15, 2009 | Nintendo DS Lite Console
Damaged ds cartridge
contact manufater and check warranty
Jan 02, 2009 | Nintendo Pokemon Diamond for DS
My ds lite will not read any games
You may have a bent pin on the game slot. Try inserting a game several times rapidly in and out. Look at your game cartridges and see if one of the contacts is damaged in the same place on all of the cartridges.
If this does not solve the issue, you will need to get your console repaired. Either the repair shop will replace all of the electronics or resolder a new game slot on your existing board.
May 25, 2008 | Nintendo DS Lite Console
Nintendo ds lite slight water damage in the game insert areas...
i WOULD SUGGEST AN ELECTRCAL CONTACT SPRAY CLEANER APPLIED TO A Q TIP
Jan 16, 2008 | Nintendo DS Lite Console
Nintendo Pokemon Diamond for DS Logo
368 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
