Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a JD 1070 4 wh dr, when running a brush hog on the back pto, what would make the pto shaft slow down under a load when cutting light brush, funny smell. Checked all oil levels.
  • Anonymous Mar 21, 2014
    WHAT TYPE OF OIL GOES IN THE INJECTOR PUMP RESIVOR
    Sniper:
  • 58 Answers
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Posted on Jul 28, 2009
    Problem Solver:
  • 8 Answers
Check bushhog for resistancesuch as bad bearings or frozen idler
Posted on Feb 23, 2012
I broke the pto shaft that runs the brush hog. where can I get the part and does the whole rear end need to come off to replce it
Most PTO shafts are a square shaft inside of a square tube to allow for it to go in and out of itself as the mower goes up and down across the ground. You should be able to unhook from the tractor and the gearbox to remove it. In the USA we have farm stores that we go to for the U Joints and halfshafts and connectors to repair them. Some of the parts are also used on trucks so Truck Repair places also. Any parts house can get you a u joint if you bring them the old one to measure.There is also round shaft models but there has to be a slip joint in all of them so no to removing the gearbox off of the mower deck.
Apr 08, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
My JD 140 discharges when I turn the PTO and/or my lights. Does my starter also charge my battery?
If your battery is old or low then it may not have the power to run the PTO. It also depend on the size of the object that you are trying to operate off of the PTO shaft and if your engine can take it. Only the rear PTO is live or uses generated electricity. The front one is independent so it probably runs off the battery.
Dec 30, 2012 | Garden
My Impact 36LP runs fine under small load (lights/TV/Fridge), however when I turn on my RV A/C unit the generator slows and stops after about 2 minutes. JD
the generator is rated for a certain static load. it may also have an intermitent loading. when the critical load value is reached the engine slows down because the load is too much. add together all the wattages of your loads to get a final load in watts and check against the nameplate wattage of the generator.
Dec 22, 2010 | Electrical Supplies
While cutting grass the pto clutch cuts off, i have to push switch in and back out to restart blades. I have replaced the switch and pto clutch
Check operator present switch under seat. Perhaps you'r moveing and not staying on switch. Check wires to pto, and seat switch.
Aug 18, 2010 | Oregon Scientific Electric PTO Clutch for...
Ever hear of a PTO running in reverse? I have my 42 inch snow thrower attched at this time and for whatever reason, it is turning the auger for an under-throw. This is on a JD 285 lawn tractor.
Is your blower running off of a belt or a pto shaft?If it is running off of a belt then you likely have a twist in the belt that shouldn't be there ,have a look at it to see if it crosses it's self somewhere.If it has a shaft then the drop box needs to come off and the gear arrangement checked out.
Jan 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
400 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
