It says recd in memory what do i do to get recd faxes printed out in memory It keeps saying open cover Driving me mad since I brought it 2 years ago I feel like swinging it from the cable HELP ME PLEASE
    President:
  • 3,085 Answers
Try unplugging the power cord for 10 seconds. A make/model number would be helpful.
Posted on Jul 28, 2009
I have a samsung SF4500c fax machine and I kept having memory received XX% flashing and the memory kept getting smaller and smaller. I unplugged the unit for 10 seconds plugged it back in and now everything is printing out.
Posted on Aug 18, 2009
I have a similar problem. My panasonic KXF-HD331 is saying fax in memory. How do I access the fax? Thanks.
Posted on Aug 14, 2009
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
Lexmark X5650 says faxes in memory. Already went to another mode. How do I get faxes out of memory?
Once you navigate away from the fax mode when a fax message goes into memory, you will lose the message. If this happens again, try not to navigate away from the fax mode. The "fax in memory" message usually pops up when the printer's not able to continue printing the fax due to a very low ink level. Just open the printer (w/o navigating away from the fax mode) > replace the ink cartridges > close the cover > print the fax.
May 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Step1: To clear the message follow the steps listed below:
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-3.Check the print head's position.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Step2: Check if the machine has faxes in its memory
1.Transfer the Fax Journal Report
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Memory received but i am not able to received fax
Please change the toner and feed the papers. It will print all the faxes recd in memory.
Nov 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
FAX 560 Brothers displays message "Memory Full"
Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
Printing a Fax in Memory
If you have Fax Storage ON for remote retrieval, you can still print a fax in the
memory when you are at your machine:
1 Press Function/Set, 8, 4.
2 Press Start.
3 Press Stop.
(See Turning On Fax Storage, page R-2.)
Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
My fax machine is saying cover open when the cover is closed
unplug it and leave it unplugged for a minute then plug it back in and turn it on
Jan 06, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
BROTHER FAX/TELEPONE T76
Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
163 people viewed this question
k24674
jasbo
jasbo
