Question about KitchenAid Refrigerators
Kitchenaid superba 48'' ice-make problem - no water into tray
Kitchenaid superba 48'' built-in ice maker not making ice. No water is being let into the tray. Manually filling the tray works, but is a short term solution. Can anyone suggest what could be wrong?
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 146 Answers
SOURCE: Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
Posted on Dec 19, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
SOURCE: kitchenaid superba ice maker not working
i HAVE REPLACED THE MICROCPTR, 046.106.4389102 PER EARLIER DIRECTION. THE ICE MAKER STILL DOES NOT WORK
Posted on Oct 28, 2008
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
Kitchenaid superba ice maker not making ice
Put some water in the tray. Let it freeze and once frozen will the ice then empty into the ice bin? If yes then the problem is possibly one side of the water control valve is defective. This is not the correct water control valve for your model number. HERE You need to provide the correct model number first.
What is the model number? I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | KitchenAid Refrigerators
Kitchenaid superba the ice maker not filling up and making ice
dear owittione perhaps the tray if its plastic maybe its cracked and the water drains out while filling check to see if there is a clump of ice in the bin and if so replace the ice tray no if is metal maybe the same thing is happening also check for the clump of ice in the bin. Now if you dont hear any water going in the ice tray maybe the magnetic valve in the back of the fridge is bunded out or the hose from the tap to the valves has a leak or the hose from the valve to the ice tray has a leak . Check around for water puddles if formed. Those are the probable causes that can lead to your problem ofcourse if the refrigerator over all is working fine. good luck. Regards Tony.
Dec 02, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kscs25fkss00 superba - water not flowing to icemaker but water dispenser works - there is not ice blocking line/tray
Most times that is caused by the dual water control valve on rear of the refrigerator. You can test the ice maker by filling with water and letting it freeze. If the ice drops then the valve is the problem. If the ice does not drop then the ice maker is were the problem is, Thanks, Sea Breeze
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water is pouring out of the top of the ice maker
you have to replace the ice maker .the water is metered via a timer built in it, the unit is not wrth servicing. they cost around 50$ you can do it yourself, they come with instructions. Good luck.
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
223 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
