Question about KitchenAid KGSC308LSS Gas Kitchen Range
Broil ok but bake not work - KitchenAid KGSC308LSS Gas Kitchen Range
  • 5,911 Answers
If the model range you have this listed under is correct, the problem more than likely is a bad igniter on the Bake manifold. Each manifold has its own igniter. Since the bake feature gets used more often it tends to wear out faster. The following link explains oven igniters and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Good sources to find a replacement igniter include:
searspartsdirect.com*
appliancepartspros.com*
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best price.
* These two sites also provided excellent exploded view diagrams to assist in part identification and assembly.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Posted on Jul 28, 2009
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
What could be the problem when i put the oven on broil every thing is ok the top element come on ,but when i put it on bake only the bottom comes on
Hello, W/D here.
That's the way it is supposed to work. The top element comes on only for broil, but not for bake, and the bottom element comes on for bake, but not for broil.
Best regards, --W/D--
Feb 22, 2011 | Maytag Ovens
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Viking broil igniter does not glow, works ok on bake cycle
There are three separate igniters, one starts the broiler and the other two are bake ingnitors left and right.
So the bake circuits ignitors work and the broil doesn't
Replace the ignitor
The part number for all of them is PB040001
May 02, 2008 | Viking Kitchen Ranges
KitchenAid KGSC308LSS Gas Kitchen Range Logo
205 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
