Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag quiet series 200 dishwasher won't start
It suddenly would not start and NO lights on the keypad would light up. Started latching door and opening and relatching and also started pushing the pad area in and out and all of a sudden it started working. Only problem is, it won't stop when "cancel" is pressed. I quickly loaded some dirty dishes in while the water was filling up in the bottom and when it started spraying closed the door to get a partial load cleaned. What is the solution? Conrad
I had a similar problem. Turn off the power to the dishwasher. Open the door and remove the screws on the back that holds the door together. Now, locate the black control module and remove the cover. Look down at the bottom left of the control module and you should see a ribbon cable. This is the cable that connects the door keypad to the control module. Unplug the ribbon cable and the plug it back in. On my unit the ribbon cable was not making good contact and only half of the keypad was operational,
Hope This Helps !!
James D.
Posted on Feb 26, 2011
I tried everything to solve the blinking start/delay button. Took inside door cover off and checked everything. Didn't buy that control had to be replaced at 100 bucks. Solved problem by taking off door mechanism, pushing switch in (to fool it into thinking door was closed). then removing the two switches at side of door latch mechanism (they pull off horizontally with gentle rocking - out towards the side of dishwasher, not up or down) check that connections are clean and corrosion free, if necessary clean with contact cleaner or electronics cleaner. Put back together and problem solved. The switches will only come off with the mechanism in one position, so if you can't pull off the switches easily check the door latch mechanism. You have to push it in. Tina M.
Posted on Apr 12, 2011
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
Maytag built in dishwasher quiet series 200. Door closed and latch won't release to open door.
insert flat head screwdriver in side of handle and pry out or use dinner knife(butter knife)
Aug 13, 2010 | Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Keypad does not work
Time to buy a new one I guess.
Go check the fuse braker, it tripped probably.
Did you close the door properly , push it hard with a slam. It will start working. Jiggle the float inside the up and down.
Vitally
May 11, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher will not start
Maytag quiet series 200, all lights are on the selector panel, when I press start nothing happens. I have already replaced the door latch control last week....Now What?
Apr 27, 2009 | Dishwashers
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Maytag quiet series 200 won't start
Does it help to push it more tightly shut...or fiddle with the latch.
Mine is not running consistently unless we push the door shut tightly. Others here also report problem with the safety latch causing this washer to quit. May have to replace the part.
Oct 18, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
4,008 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
