Picture ''breaking up'' on Samsung LCD
Folks,
I have a LNS-4096 LCD that is ''breaking up'' on all sources - it looks like the image is being blended up and distorted. This happens usually when the TV has been off for a while and will go away if I turn the TV on and off frequently but will usually come back. I took it into a local authorized Samsung service location ''TV is out of warranty'' and I was told it was the T-con board that needed to be replaced. I work at a high end AV dealer in dallas and have sold Samsung for years - I am quite familiar with component level service as well - so I have purchased the Samsung service manual for this TV. I can not seem to find a part number description of the ''T-Con'' board on the parts list however - Can you provide me the part number the service department needs? - Also, I did some research and found that the T-Con board may be a consistant issue on some of these panels and that a firmware update may fix - see: http://forums.cnet.com/5208-13973_102-0.html?messageID=3020041&tag=forums06;posts#3020041
Is there a recent firmware I could get from you to see if this makes any improvement?
Thanks!
  • 191 Answers
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
for bn94-00963b go and change your backlight inverter
Posted on Oct 05, 2008
  • 7 Answers
SOURCE: westinghouse lcd tv parts
you need a buffer brd. assy i have 27 years exp. as a tv repairman beleave me the prob is your buffer board
Posted on Dec 23, 2008
  • 54 Answers
SOURCE: got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
Posted on Feb 28, 2009
welcomejee
  • 10594 Answers
SOURCE: Sudden loss of picture and sound on 40
I do not think T-Con can shut down TV, all it can do to blank the screen, I mean stop picture data towards LCD panel.
Sony would not give T-Con separately as its counted part of LCD Panel but its available in some part shops.
Let me know model number of TV and what boards you have been replaced in TV.
Are these power supply and main boards.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thanks so much for the speedy response. I don't know which 2 boards they replaced, but will find out. Thanks again "
SOURCE: VW37LHDTV10A. is my model number of my tv and a
backlight inverter is different from lcd controller.
Posted on Dec 28, 2009
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LNS 325 1D-the screen is blue-no picture but perfect sound-what is wrong? Thanks
Hi m5720,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Is there any High Voltage DANGER when repairing a Samsung LCD TV
Just be careful around capacitors, which could possibly still hold a charge. Otherwise, there are warnings on parts that you shouldn't touch. I would say that the biggest thing to watch out for is getting stabbed by the sharp solder points. I always forget how much it can cut you.
Aug 10, 2009 | Samsung LN-S4051D 40 in. LCD Television
Intermittently, picture seems to break up into
replace the cable from the source. if the images tiles up it could be the cable and I suggest doing this first: replace the cables, they are the lowest cost to check, and in some cases the cable company will replace the length of cable from the TV to the wall for free (or part of your monthly payment). You could always make your own the stuff for that can be found on sites like www.compressionconnector.com of course you could always buy the cable if needed. I am assuming this is occuring during normal TV viewing. if it occurs while watching DVDs or from other sources you likely have a problem with your TV and may need to get it repaired.
Feb 18, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LNS 4051D color problems
1.T-con board or related cables problem -- 60%
2.replace Main Board -- 40%
Jan 25, 2009 | Samsung LN-S4051D 40 in. LCD Television
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
NO PICTURE, MENUS... ONLY SOUND
same happend to my lns 4692....control board is gone and since it's attached to the screen...everithing is gone,my tv is under warranty,but Samsung did nothing in 3 (three!!) months,though they promised service,repair,replacement..u name it..!!I just finished a complaint letter to attorney's general office,NJ,consumer protection divisin,BBB,and others...let's see what happens...I WILL NEVER BUY SAMSUNG AGAIN, AND THOSE OF YOU WHO WILL, THINK ABOUT WHAT HAPPENED TO ME...SO THINK TWICE..OR THRICE...HA ,HA...SAMSUNG, IN ENGLISH IS...SOME SUCK!!!
Sep 19, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
759 people viewed this question
Top Televison & Video Experts
Electro Med Services...
