Tablets & eReaders Logo
A
Anonymous Posted on Aug 27, 2017
Help. Me. To. Erase. Everything. On. My. iPad. Please. Help
xiangnia
Level 3:
Master:
  • Tablets & eR... Master 365 Answers
  • Posted on Dec 27, 2017
xiangnia
Level 3:
Master:
Answers
365
Questions
Helped
208502
Points
2124
Maybe you can use iOS Data Eraser to help you erase everything on your iPad. You just need to connect iPad to computer via usb cable, open the iOS Data Eraser tool. After a short time scanning, all data on iPad will be scanned out and displayed on program window Then you can preview and choose them to erase.
iOS Data Eraser Permanently Wipe out Data from iPhone iPad iPod
I need help with the passcode for my ipad
Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
1.Connect your iPad to your PC or Mac.
2.Select your device in the iTunes sidebar, and click the"Summary" tab.
3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
Now, you must have restored your iPad.
Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
1helpful
3answers
How do i fix my disable ipad
Go to iTunes then sign in, connect your iPad to the PC/Laptop and factory reset the iPad, that is the only way it can be done!
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
How can I get rid of a virus?
You should not be able to get a virus on an iPad tablet by if you do, I would hard reset it or erase the whole iPad without backing it up. Then I would reinstall everything manually. If you back it up and restore it from backup, the virus will still be in your iPad.
How to reset iPad
Reset iPad:
  1. Press and hold the Sleep/Wake button until the red slider appears.
  2. Drag the slider to turn your device completely off.
  3. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
To Reset iPad to factory settings:
  1. Click on Settings > General > Reset
  2. Then if you want to completely remove everything from your iPad click on 'Erase All Content and Settings'
Purchased second hand ipad cannot activate it because it needs activating with the previous owners icloud details , cannot get in touch
Put ipad back to default settings. Settings menu--This will erase everything on the iPad so you can start as a new user. It will erase original users saved info so you can input yours
3answers
How do I can reset my IPad?
Try putting your iPad into DFU mode, and then restore it with a computer with iTunes installed.
Please note: this will erase and delete everything on the iPad.
The article can be found here, on Apple's website:
http://support.apple.com/kb/HT1808
Hope this helps!
IPad mini apple have password key pad won't take my password
Firstly you could go into your iPad settings>General>Reset(at the bottom)>Erase All Content and Settings. Secondly if the first one didn't work or you cant unlock your iPad install iTunes onto your computer plug your iPad into your computer and click reset.
Hope This Helps.
But this will reset everything and will remove all apps+data.
Ipad said disabled
please follow this step and fix it. God bless you
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPad will erase everything on it, so make sure everything on the iPad is stored elsewhere prior to restoring. To restore, connect your iPad to a computer with the latest version of iTunes installed. When your iPad appears under the devices menu, click the restore option under the summary tab. If you haven't backed up your data already, choose the back up option from the pop up window. Click the restore button to restore your Touch to factory spec.
Bad logic board
If attempting to restore the iPad and diagnosing does not fix the problem, the issue is probably the logic board.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
