Question about Cell Phones
Help with functions on P1i
Hi, I, Rebecca recently recieved as a gift the P1i phone. It also has a M2 memory ''thingie''that copies from PC to phone. The thing is i really am having a hard time familiarizing myself with them,so iam counting on you, the top experts to get me started with my new toys!! I will go ahead and say Thank You so very much. Keep up the good work...... Sincerly Rebecca Perez San Diego, Ca. 91950 (619) 267-5064
Greetings! I have a SanDisk M2 memory card for my
-u- can always contact geek patrol tell them what -u- -r- going through they may have the answer -u- -r- looking for//
Oct 29, 2013 | Electronics - Others
Tip
The P1i doesn't use SD cards, it uses Sony Memory Stick Micro (M2) cards.
If having issues with your SD card and camera.  Copy all files to your PC and reformat the card.   Then transfer any necessary files back to the SD card from your PC.  If you continue to have issues I recommend buying a new SD card.
on Jan 11, 2009 | HTC G1
I have a 4gb m2 memory card...but it is not getting detected by my sony ericsson w595????help....can i recover my data in it???
Yes, you can recover your datas.
You can use memory card readers in PC and you can retrive your data from it.You get many memory card readers available in market you can use those.
When you put on the PC it shows the folders which is present in the memory card.You can copy the content to the PC drives.
Thanx
Jul 06, 2010 | Cell Phones
I need delete a corrupted file on my phone memory because it keeps on switching off. when i switch on, it switches off after about 10 seconds my phone is nokia 5610,s40v3
hi the only thing to do is to restore the phone to factory settings. try this remove the memory card after you have back up your sim contact and messages that are stored on phone memory, then press this *#7370# then say yes. copy all that you have on your memory card to your pc make sure you scan your memory card. you can format the memory card too because it might just have been infected, copy your files back from pc to phone.
Jun 20, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Where to find my recieved files( beams received) through bluetooth on sony ericsson P1i
Dear friend:
If the transfer is completed you can find your file in the messages inbox folder. However, if it is NOT fully transfered it is located in the cashe (one of the hidden directories) of the Symbian OS. To delet or copy it, simply use MyPhoneExplorer and go to "File" management tab. there, in the below address you can find the file:
\Phone Memory\Shared\obex\
You can find it.
Hope you find this solution useful.
Gecko
Nov 13, 2009 | Sony Ericsson P1i
ERROR IN INSTALLING AND UNINSTALLING P1I
What I did is use the SonyEricsson's Update Manager, So I updated the phone to its original state again... and the phone is back to its normal state...
Thanks you!
Mar 22, 2009 | Sony Ericsson P1i
Problem connecting phone to laptop
I haven't acutally got my P1i and laptop with me so I'll see what I can do from memory. When you put the P1i in file transfer mode it becomes a USB mass storage device and just presents the M2 memory stick in the side of the device as a drive letter in Windows Explorer. However, if in Phone mode it expects the 'mrouter' program to connect the phone to PC Suite using the DCU-60 cable as a serial line. In the system tray you have an mrouter icon which when you right click allows you to select the serial port to connect to the phone. You may need to adjust this recognise the phone. There are also some drivers required for the mrouter interface. Check device manager and make sure there are no yellow question marks in the ports section. You can also use Bluetooth to connect mrouter to the phone, this'll become clear when you look at the port settings! Hope this helps.
Dec 17, 2008 | Sony Ericsson P1i
P1i, Calendar problem - Not enough memory
if its saying "not enough memory" u need to go to task manager and end all the open files you have multitasking. look up the top in task manager and u will see Recent and Open.
Mar 24, 2008 | Sony Ericsson P1i
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
