I can not upload photo images when trying to create a new show. It scans the photos in my relevant file apc.jpg images but then states can not load the images and lists all the images by name
SOURCE: Roxio Creator Basic v9 does not work with jpg files
The "burn image" option you are getting into is for burning full CDs of data, like a 1 to 1 copy.
You want to click on the Data Disk option. Then you can add files, or whole folders of files. You can change the default name "Volume Label" to what ever you want.
Hope this helps.
SOURCE: help with nero photo viewer
How are you trying to open it? Are you trying to open it from within the application itself or by 2x-clicking on the .jpg?
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
SOURCE: Digital Photo Keychain
My copy of Photo Viewer came on the provided disk. Run set up to load it (if you do not have a disk go to the key ring manufacturers website). When you use Photo Viewer make sure that your key ring is attached to a USB port prior to starting the programme otherwise it will not load.
SOURCE: In PSP Photo X3 Project Creator Photo, the JPG
did u download this??.....if u did you didnt extract the crack properly...if its not dowloaded...then try uninstalling then reinstalling....hope this helps?
