Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT-53WX53 won't power on, light flashes 3 times
Was watching TV the other night on our Panasonic PT-53WX53 53" RPTV, when the picture suddenly went green for a few seconds, then the TV shut off. If I attempt to turn it on, it will start up then immediately shut down, and the power LED blinks red 3 times.
I've read here and elsewhere on the internet that this is probably due to a fried convergence IC, the
STK392-110. I've just ordered two new ones of these. I won't be able to try them until Sunday, but I am planning on removing the old ones from the PCB and soldering the new ones in its place.
I also see that there is a convergence repair kit sold on the internet that contains those two IC's and 6 2.2 ohm 2 watt resistors. I'll test the current resistors ( R7048, R7049, R7050, R7053, R7056, R7059) to make sure that they aren't fried either.
Am I on the right track? Once I replace the IC's, will the convergence be whacked up? Will I be able to adjust it via the user menu, or will it be necessary to go into the service menu (and if so, how do I do that)?
Thanks in advance.
  • andrewwski Aug 02, 2009
    Fixed it! Turns out it was the convergence IC's, I replaced both and all is well. Tested all 6 2.2 ohm resistors and they checked out fine, TV powers up and I adjusted the convergence back to where it should be.
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: i had projection tv.modle#pt-47wx49.i had
R7050 and R7059 are both 2.2ohm 2watt Resistor R7001 is either 82 or 8.2 ohm if you give me the colors of the bands on that resistor I will let you know for positive what the value of R7001 is
Posted on Apr 27, 2008
SD Tech
  • 14553 Answers
SOURCE: pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Posted on Oct 26, 2012
Pt-53wx53 Panasonic Projection TV Turns off
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
TV will not turn on. Power light flases three times at a time????
3 flashes high voltage shut down, if you like I can show you what parts need replacing contact me at the link below....
http://tvtechwork.webs.com/
Oct 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Black screen
how many times does the red light flash?
Techman
May 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Sep 08, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
339 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
