Question about Cameras
Focus ring my focus ring is stuck
  • 57 Answers
Try taking the battery out and then back in and returning it on
Posted on Jul 28, 2009
  • Brittany Poteat
    Brittany Poteat Jul 28, 2009
    try taking the battery out and then back in and returning it on
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Sep 30, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Key stuck in ignition of ford focus. column not locked
I had this same problem with my 2006 ZX4 Ford Focus. My focus has an automatic transmission. In order to get the stuck key out of the ignition, I discovered that there is sort of a "ring" on the gear shift that will sometimes slip down a little and cause the ignition to lock the key in place. The ring is located just benenth the plastic gear shift handle, right on the end there. If you push the ring up, you should be able to get the key out of the ignition. I found this out by accident. I know that sounds weird, but it actually works; at least it did for me. At first, I thought I hadn't put the gear in park. The ignition will not release the key if the gear isn't in park or if the steering wheel isn't in its lock position. I think most cars work on this principle; that wasn't the case here. For all of you 2006 Ford Focus owners out there having this problem, try my suggestion and I would also spray some WD-40 in the ignition hole too ( after you get the key out) . I hope this helps you folks out there. Good luck and have a nice day!:)
Sep 09, 2011 | 2006 Ford Focus
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
When I turn in my Olympus Camera, the screen background is blue and it says the following: D: 5f0a 5f08 5f0a 5f08 5f02 The camera model no. is Stylus 710
  1. Replace the batteries with new ones.
  2. The focusing ring may be stuck or jammed. Try and spray some compressed air into the lens to try to free up any sand or dust that may have gotten in.
  3. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
  4. Try and move the lens to the left or the right until the lens pops out.
  5. If that doesn't help, the camera will have to be totally disassembled to get at the focusing ring.
Feb 21, 2011 | Olympus Stylus 710 Digital Camera
When power ON the screen displays"Lens Error!" & lens does not open.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
Camera wont focus
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
Thanks..!!
Rating the solution is highly appreciated.
Sep 14, 2010 | FUJIFILM FinePix JX250 Digital Camera
Kodak Easy Share V610..Error 45???
or.......
Good luck and have a nice day.
Sep 11, 2010 | Cameras
Camera Problem
or.......
Thanks for using fixya,
May 09, 2010 | Kodak EasyShare CX7330 Digital Camera
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Casio s500 digital camera
This error indicate that focusing ring got stuck or jammed due external shock, liquid, sand & dirt etc. enters the camera.
  • What you can try to do is spray some compressed air into the lens area to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
Else your camera need to be disassembled to get at the focusing ring.
Mar 18, 2008 | Casio Exilim EX-S500 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
