My Acer 5100-5023 will not power on with power the
My Acer 5100-5023 will not power on with the power supply cord or with the new battery I installed. The power light and fan will come on for about 20 seconds then off again. I bought it new about 2 years was working fine and just started doing this all at once.
Thanks for any help.
  • brb427 Aug 03, 2009
    Replaced the ac adapter. Worked great
    Thanks
  • 408 Answers
Your ac adapter maybe producing to low voltage.It may be having a hardware conflict such as a bad video card,a Hdd thats seizing,bad CPU,or even a heat effected motherboard.Excessive heat being the cause of most of the above problems.
Posted on Jul 28, 2009
My Acer One notebook won't operate on electric power or charge the battery. I recall reading an on-line article about holding down the power button for 45 seconds and that worked once or twice, but it no...
Try this first, Unplug the power cord, remove the battery, Hold down the power button for 30 seconds, reinstall the battery, try to power it on, If it doesn't try to power on, The battery needs replaced, plug the power cord back in and power it on, If it still won't power up, then it's the power supply.
Nov 29, 2010 | Acer Aspire One PC Notebook
I have a ACER Aspire 1640 model ZL8 I replaced the battery and power supply. I plugged in the power supply to the unit with the new battery installed. the unit started immediately but went to a blank...
I'm facing the same prob ,system power on,cpu fan spin for 5 to 10 seconds n then stop.(system is still on with leds)no display or sometimes the acer logo only.
I opened the system n found the following Ic over heating
(24 U4 EC PC97551 (Power and I/O Connector)
24 is the number on service guide
any suggestions?????????
Sep 02, 2010 | Acer Aspire 1640Z Notebook
Acer Aspire 5920 will not power on at all. The
Just to make sure:
1. With battery alone in notebook, and no power cable, do you get power?
2. With the battery taken out, and power cable plugged in, you do get power?
IF YES to the above two questions
... and u can get power using the power cable but not using the battery, then your battery is dead and u need a new one.
Mar 16, 2010 | Acer Aspire 5920-6727 Notebook
I have an acer aspire 3680 computer, Before the battery wasnt working so i bought a new one. Well now the battery came and i tried to charge it, but its not indicateing that its charging and won't charge...
Taking the fact that you already replaced the battery into consideration, chances are that you have a faulty cord. Looks like you're going to need a new one mate.
Sep 16, 2009 | Acer Aspire 3680 Laptop
Acer 5050 laptop no power
I have the same thought.
But please check the new power adaptor has the same output voltage as the old one.
If same the power supply unit needs to be changed on the laptop.
All the best!
Sep 02, 2009 | Acer Aspire 5050-3242 Notebook
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Battery not charging
It could be the power cord if without the battery the laptop will not power up with the cord.
However, if it does power on, the power cord is fine and it could be a motherboard problem
Mar 05, 2009 | Acer Extensa 4620 Notebook
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Acer Aspire 5000 Laptop
Have you tried changing the power settings,in control panel go to power options and change the time settings for when the laptop is plugged in and running on batteries.
Also change the power scheme to Portable/Laptop.
I hope this helps,please let me know WF
Aug 20, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
