Question about Hunter 235 Fan
Hunter 93886 fan
Two fans on same wall switch. Wall switch on, fans and lights off, fan may come on at any speed, then change speed or turn itself off. Lights also will come on and off by themselves. Not interference from other fan remotes or TV remotes.
  • 631 Answers
You may be drawing to much amperage for the switch to handle both fans. You may be underwired if it is an old house. you can hook wires together without switch in place and see if everything keeps working but don't hook them together with the power on. Also don't run very long as the wires could heat up. Run for about 5 minutes and turn power off and check heating of wires.
Posted on Jul 28, 2009
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Magic fan
u need to show a good technision of electronic
Jul 19, 2008 | Hunter 21617 Palermo Brushed Nickel...
Wall switch control not working
Fan speed and light intensity are controlled by the remote as indicated in the instructions for the fan.
Dec 12, 2013 | Hunter 1912 Mission 21978 Ceiling Fan
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter fan model 21617 remote fan won't turn on light from wall switch
You mean only the light? and the fan is working? Have you checked the light bulb? If it's ok, then checked on the wall switch. If is also ok, then probably there's is something wrong with the wiring in the fan.. It's either a bad or loose connection
Jul 01, 2010 | Hunter Ceiling Fan Light Switch Control
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Quit working
first turn it off, then rotate the fan, half turn and try to turn if on again. if it start running again you have a faulty motor, and need to replace it. or if the problem continue, try replacing the switch in the wall.
Nov 24, 2007 | Hunter 23852 Classic Original Ceiling Fan
Hunter 235 Fan Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
