Question about ASUS P5B-E Motherboard
Asus P5B -E Plus motherboard Beeping during bootup (Repost)
I refer to the problem I posted yesterday:
"Using an Asus P5B -E Plus motherboard for 2 years now with no problems. But when I boot up my computer now i get 1 long beep followed by 3 short beeps and no display on my monitor. I have to reset the CPU to get the same series of beeps, but then I will get the display back and the computer will boot up normally. However, it seems I can no longer run the game I play properly, World of Warcraft. I get stuttering, cracking sounds and very bad frame lag when I try to tab out of the game. I am unable to pinpoint the problem I have presently and need assistance. If possible please explain step by step as I do not have alot of experience or knowledge on troubleshooting my CPU."
I have since reseated my graphics card twice to no avail. I still get the same beeping from my motherboard when I boot up. However, I noticed that this problem only seems to affect the game World of Warcraft. When I run Half-life 2 or Left 4 Dead for example, they run smoothly like before. I'm at my wits end here and need further advice.
Thank you.
  • 2,418 Answers
If you are hearing the code right. 1 then 3 you can have a cpu bad or bad memory, remove memory or find (borow) new. try that, also try a new battery Time error. Then start from scratch - take everything loose from the board nothing but the board, one stick of memory, no hard drive, no video card, if you get the same code your cpu is going. If you get different code try the video card if you get the old code thats the problem. Clear as mud? Yep clear as mud.
Posted on Jul 28, 2009
  • 952 Answers
Thanks for using FixYa!
Its possible that the problem that you have right now has something to do with your memory modules. If you have several memory modules. try to take them all out then add them back one by one. this process will isolate any bad memory module. Also, after you take out your memory modules try to clean the gold contact points with pencil eraser. This will take out that static build up from your memory modules.
I hope this helps. I hope you get to play WoW now.. i know the feeling of not being able to play my toon. Have a nice day.
- HotRatchet
Bios problem what are new drivers bios
P5B-E Plus Uses 100% All High-quality Conductive Polymer Capacitors! - Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® P965/ ICH8R
- Dual-channel DDR2 800/667/533
- Fanless Design - Stack Cool 2
- PCI-E Gb LAN/ 8-ch HD Audio
- AI NOS™ / AI Gear / AI Nap
- SATA on the Go/ 1394/ Noise Filter
  • Another option is through the Internet. Launch the utility:
Start > Programs > Asus > ASUSUpdate
Follow the directions.
There is also ASUS EZ Flash.
Make sure that you do have a copy of your current or original BIOS, if you have the CD that came with the MoBo then you are golden.
Sep 20, 2011 | ASUS P5B-E Motherboard
Would an Extreme power plus 500W work on a asus p5b-vm main board^
Yes, the Coolermaster Extreme Power Plus 500w has the required connectors to work with the ASUS P5B-VM Motherboard.
Sep 12, 2011 | ASUS P5B-VM Motherboard
Hello, I have a problem with my audio driver for Asus P5B SE Motherboard. My 5.1 Logitech X530 sound system doesn't work very well (only the two front speakers working). I probably need to change the...
I was also facing the same problem
1. Universal audio architecture which will enable your motherboard to detect audio driver it can be downloaded from here
2.Now try to download the latest audio driver from here
Jan 27, 2011 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
Using an Asus P5B -E Plus motherboard for 2 years now with no problems. But when I boot up my computer now i get 1 long beep followed by 3 short beeps and no display on my monitor. I have to reset the CPU...
this beep code is described from ASUS as a video card issue. Perhaps your chipset is failing. if you are using a 3rd party video card. try removing it or re attaching it. If you are not using a 3rd party. i suggest you do. and disable the onboard in the bios.
Jul 27, 2009 | ASUS P5B-E Motherboard
P5b-vm se asus driver
You can download the drivers for your motherboard from asus here:
http://support.asus.com/download/download.aspx?modelname=P5B-VM SE&SLanguage=en-us
just select your operating system
Mar 31, 2009 | ASUS P5B-VM SE SKT775 G965 MATX...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Psb-mx/wifi
The problem - I guess - is that this CPU is not recognised correctly by the board. To solve it, just update to the latest BIOS, using either AsusUpdate or manually from www.asus.com
Dec 06, 2008 | ASUS P5B Deluxe/WiFi-AP Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
ASUS P5B-VM DO Motherboard
Please update your BIOS if necessary to do some fixes, optimization, and even hardware or software support.
May 28, 2008 | ASUS P5B-VM DO Motherboard
ASUS P5B-E Motherboard Logo
720 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
