Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I want to change the dialing from pulse dialing to tone dialing
  • 118 Answers
Check this page out. find your model phone.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Posted on Jul 28, 2009
  • 5,603 Answers
Usually this is a small slide switch on the phone or the base. It may even be on the side or bottom. It may be labeled P or T.
shaggyrat
  • 1224 Answers
SOURCE: how can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Posted on Jun 01, 2008
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
Posted on Dec 12, 2008
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Posted on Jan 23, 2009
smartr10U
  • 1305 Answers
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Posted on Jun 05, 2009
SOURCE: Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
Posted on Aug 08, 2009
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
How do I change pulse to tone dialing?
Are you sure about the phone model number?
Tone/pulse is set in the common equipment (KSU) configuration, not the individual set.
Press Feature 9*80 to see the system software version.
Jan 27, 2015 | NorStar M7324 Telephone
Changing to pulse
Enter SetUp. Look for Global setup. You have the options Area code, Dial Mode. This last option is the one that allows you to change between Pulse and Tone dialing.
Dec 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
209 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
