Question about Hayward H Series
Hayward heater h1001d1 shakes and rattles after startup
    Champion:
  • 246 Answers
Water to slow for the heater or the by pass valve is bad
Posted on Sep 01, 2009
I have ahayward H1001D1 above ground pool heater running on nat gas has worked for 3 seasons with no problems last week heater started to make banging sound as if it was rapid cycling ichanged filter...
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Sep 04, 2010 | Hayward Pool & Spa
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Shaking H100ID Hayward Heater
You can try to get a welding shop to tack it back in place (I do not remember who to credit for that but it was not my suggestion) and see if it stops.
The exchanger is expensive as a DIY part...about $350...but if that is all that is wrong it is a lot cheaper than $700+ for a whole new unit.
Jul 18, 2009 | Hayward H Series Induced Draft Abg 100,000...
My Hayward AG 100,000 btu heater ran well for the last two seasons. This season I hear a rattling type noise, and the hose that feeds the heater shakes at times. Other times the noise and shaking subside....
That plate should not move at all. If it is moving is is damaged. In the past that meant replacing the heat exchanger but I recently had someone tell me they took theirs to a radiator shop that tach welded the plate in place and it works fine now. Either way, the rattle is from water boiling in the unit due to poor flow through the heat excahnger. The plate we are talking about is what controls that flow.
Jul 06, 2009 | Hayward H Series Induced Draft Abg 100,000...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
May 25, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward H Series Logo
303 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
