Question about Tools & Hardware - Others
I have an 18 horse vanguard that was fouling plugs after short use. i took off the air cleaner and inspected the choke linkage and found that there is small line coming from the carburetor that doesn't attach to anything.Further back on the carb is a nipple that looks like it should have the same size line attached but it doesn't. the line faces away from the carb towards the front of the engine, is there something missing, like a valve that would attach to this line and then have another line back to this other carb nipple????
  • oldfordguy Jul 29, 2009
    Ok I attached the hose to the nipple behind it and the engine runs fine until I put the air cleaner back
    on. The filter is not new but I can see light through it, I tried just putting the air filter without the outer
    spongy ring but the results were the same. The engine will only run well without the air filter. Are these engines that particular that they wont run if the air fliter is not new??
  • 3,037 Answers
Yes, this is a valve breather tube and would foul the plugs if not connected. If you connect it back up, it shouldn't have any problems. I would also take a torch and burn out the excess gas in the chamber. Let me know how this turns out.
Benjamin
Posted on Jul 28, 2009
  • Benjamin Patri
    Benjamin Patri Jul 29, 2009
    The air filter is dirty and the air can't get through it then, you need to replace it and then you should be set. You should be able to get one from the place you bought this unit from.
I have a 18 hp b&s vanguard engine and it will only run on half choke any ideas
it,s not getting enough gas, your carburater needs cleaned and there's an mixture screw on most engine's hope this helps
Sep 22, 2012 | Briggs & Stratton Electrical Supplies
Turn key to start and nothing happens. All lights are on, battery good. Doesn't turn over---nothing. Switch or starter or some kind of relay??? HELP!!!
For 1999 Buick LeSabre - but you took #1 off the list, so here's the whole "failure to start" list:
Priority Action Part Type Cause
1 Inspect Battery Battery Discharged or Faulty.
2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil Faulty Ignition Coil.
6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter Starter Motor Faulty.
9 Inspect Fuel Pump Low Fuel Pressure.
10 Inspect Starter Relay Faulty Starter Starter Relay
11 Inspect Fuel Pump Relay Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Motor Faulty Starter Motor
15 Inspect Fuel Injector Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainer
17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank Fuel Tank Empty.
19 Inspect Carburetor Carburetor Flooded or Faulty Choke.
20 Inspect Distributor Rotor Distributor Rotor broken, burned contacts, or loose
21 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Sep 12, 2011 | 1999 Buick LeSabre
I have a lot problems when i need to start the engine in my genesis 2.0 coupe why is this,,i took the car to the dealer but cant find a problem,they say battery is ok
You already took #1 off the list.
The national auto parts chains (AutoZone, Pep Boys, and Advance Auto Parts) will hook up a
diagnostic tool to your car to perform a Charging System diagnosis for free - its an easy
way to exonerate & differentially diagnose your Alternator/Battery/Voltage Regulator.
4 Inspect Distributor Cap Distributor Cap Cracked or Burned contacts.
5 Inspect Coil - Ignition Faulty Ignition Coil.
10 Inspect Solenoid Switch Faulty Starter Solenoid Switch.
11 Inspect Relay - Fuel Pump Faulty Fuel Pump Relay.
14 Inspect Starter Motor Faulty Starter Motor.
16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The ECC.
20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
21 Inspect Distributor Rotor Burned Distributor Rotor contact
Sep 04, 2011 | 2009 Hyundai Genesis
VERY ROUGH IDLE NO EXCELERATION
Try a few if these ideas...
1 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s).
2 Inspect Hose (PCV) Clogged or Collapsed PCV Hoses.
3 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s).
4 Inspect Distributor Worn, Damaged or Faulty Distributor.
5 Inspect Catalytic Converter Clogged or Faulty Catalytic Converter.
6 Inspect Fuel Pump Low Fuel Pressure.
7 Inspect TimingSet Slipped TimingChain or Worn TimingGear(s).
8 Inspect Knock Sensor Improperly Connected or Faulty Knock Sensor.
9 Inspect M.A.P. (Manifold Absolute Pressure) Sensor Faulty M.A.P. Sensor.
10 Inspect Throttle Position Sensor Faulty or Incorrectly Connected Throttle Position Sensor.
11 Inspect Mass Air Flow (MAF) Sensor Damaged, Loose, or Faulty Mass Air Flow Sensor or Circuit.
12 Inspect Air Cleaner Temperature Sensor Damaged or Faulty Air Cleaner Tempature Sensor.
13 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
14 Inspect Piston Ring Set Worn or Broken Piston Rings.
15 Inspect Timing Specification Incorrect Ignition Timing.
16 Inspect Fuel System Pressure Incorrect Fuel Pressure Being Delivered to Carburetor or Fuel Injection System.
17 Inspect Fuel Filter Clogged or Dirty Fuel Filter.
18 Inspect PCV Valve Plugged or Damaged PCV Valve.
19 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
20 check idle stop solenoid - if faulty, could cause rough idling
21 inspect distributor cap/rotor - if burnt, could cause loss of acceleration
Apr 18, 2011 | Chevrolet Cavalier Cars & Trucks
Will only run with the full choke on
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. If no help, then the carburetor may need service. If you just obtained this saw, take it back for warranty repair or replacement. Good luck!
Nov 06, 2010 | Homelite ZR10580 FactoryReconditioned 42cc...
New fuel pump and still wont start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
May 22, 2010 | 2000 Dodge Caravan
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
When i open the throttle a little, the speed increases but at full throttle, the power drops and I lose speed. Admittedly, I bought the C/Saw from a market 'as seen' and I found a few problems like broken...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Heavy Machinery
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
