Question about Motorola Mobility RAZR V3
Ringer turns itself off in my pocket
I had a Razr, now I have a Casio Gz-1 and they both have active volume buttons when closed. No way around it, said the factory. I want a new, simple phone that won't perform this enormously frustrating trick.. I'm due for an upgrade and the dolts in the verizon store haven't a clue about their products. Any recommendations?
  • 57 Answers
You should turn your lock key on. even though it does have active outter volume you would have to click unlock and okay
Posted on Jul 28, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Casio Gz one external buttons
How long have you had it? Just call Verizon and you can get a warranty replacement if it's been under a year. Sounds like a manufacturers defect to me.
Feb 12, 2008 | Casio G''zOne Type S Cellular Phone
How do I turn the ringer back on.
You just press the up arrow until you get the volume you desire.
Jun 17, 2014 | Uniden D17602 D1760-2 D1760 2 DECT 6.0...
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
Mar 06, 2012 | AT&T 972 Two-Line Memory phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Lucent 854 phone, how do we turn up the ringer?
To Adjust Ringer Volume:
1) Press CONF, then using the dialpad press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2) Press one of the VOLUME buttons to increase or decrease the ringer volume.
To Turn the Ringer Off
1) Press CONF
2) Use the dialpad, press 1, 2, 3, or 4 to indicate which line you want to adjust
3) Press the down VOLUME until you no longer hear a tone.
Feb 28, 2009 | Lucent Lands Phones
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Volume
This issue is my biggest complaint about the phone. Setting my phone to vibrate is about worthless as the phone goes to full vol or silence. (I missed most of my calls or was startled by the loud ringer due to this "feature")
I used a small diamond file to file off the extruded portion of the buttons. I think a dremel tool would have worked best to get a nice recessed finish, but filing it smooth works also.
This helped me significantly. I can still use the side buttons when I want to, and it doesnt get pressed in my pocket.
(I wish there was a better software solution)
Nov 27, 2007 | Casio G''zOne Type S Cellular Phone
Ringer turns off when I don't want it to!
To the best of my knowledge there is no way to disable the feature...Sorry...
Oct 11, 2007 | Motorola Mobility RAZR V3
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Motorola Mobility RAZR V3 Logo
85 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
