When I turn the tv off I cannot turn it back on unless I unplug the power cord . If I turn it off at say midnight and then want to turn it on the next morning I have to unplug the power cord from the wall.
    Scholar:
  • 122 Answers
Old electronics had a true power switch that turned the electricity off. New electronics have what is called a soft power switch which means that the device is powered down to a very low low state and when the power button is pressed it sends a signal to a circuit that allows full power up. Well when the symptom you report shows up it is because the soft power circuit has gone bad. Sorry but it will require repair by an experienced technician to fix. Good Luck
Posted on Jul 28, 2009
HI NEED HELP? TV WONT TURN ON?
Unplug the power cord from your TV. Wait 30 seconds, then plug it back in. Plug the power cord into a different power outlet or power strip. If possible, try a different TV power cord.
Apr 13, 2017 | Televison & Video
I have a Panasonic LCD tv, model# TC-32LX70, S/N MY71420839, manufactured May 2007. The tv wouldn't turn on unless the power cord was unplugged and plugged back in for about 2 years. Then it
Fault with the main power supply regulator section circuit board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 20, 2014 | Televison & Video
Olevia television won't turn on unless you unplug the power cord from the back and plug is back in
One of the buttons has flattened out try the remote first and see if it will pop up, if so replace remote. Then try the one on the TV itself which is more likely...that one will require a new PC board with the buttons on it.
Jul 23, 2014 | Olevia LT42HVi 42 in. LCD Television
Tv problem help
With the plug from the t.V. unplugged from the wall outlet, remove the tv cover. Follow the power cord to the power supply's printed circuit board. Look to see if there are any damaged, bulging or burnt out (exploded) capacitors. If there are, that's the source of the problem.
Be fore warned, even though the power cord to the tv has been disconnected from the wall outlet, good capacitors still hold (store) hi-voltages that can shock & even kill you; so don't touch them unless you know how to properly discharge a capacitor. Don't underestimate the power that these components store even though they are very small.
See this video 1st : http://youtu.be/AvlNKZ8GzEg
and this one as well: http://youtu.be/B41PeSDF_dk
Warmest regards
Mar 11, 2014 | Mitsubishi WD-60735 Projection Television
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
TH-42PD50U 42" plasma from Panasonic. The TV tipped over and won't turn back on. The red power light just keeps flashing on and off.
Try to unplug and replug the power cord. If TV remains unchanged you need to call for service. The power supply board was defective. In worse case, the Y and buffers are defective, too. There are many steps needed to figure out the exact defective board. You need help from TV repairer unless you want DIY.
Aug 13, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Tv won't turn-on
ITS THE PICTURE TUBE ITS BURNT OUT - OR THE GAS HAS LEAKED OUT ANYWAY U NO LONGER CAN USE IT
Aug 22, 2007 | Hitachi (3223424A)
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
