Question about Whirlpool Duet GHW9150P Front Load Washer
Power will not turn on
Nothing happens when i press the power button.  there is power going to the machine though.
  • Anonymous Mar 29, 2014
    samsung WA10U3.when i press the power button,nothing happens.please advise.thanks a lot.
  • 29 Answers
Test the resistance of the power button you will need to remove the wires from it first hold button down put test leads on each side or button it should read 0 if not replace it.
Posted on Jul 28, 2009
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
TV set will not switch on.either with the remote or with the power button. Intermittent fault.
From my experience, your inverter starter circuit is bad. The "click" then nothing or in some cases a popping sound from the speakers as well, means that one or some of the capacitors on the main power section of the control board are leaking voltage to the point that they no longer have a strong enough charge to "jump" the circuit that starts the picture, and when that happens it turns the set back off. leaving the tv alone for an hour or so will allow it to charge the capacitors back up just enough to jump it once and then the problem comes back. There is no easy fix for this problem and soon it will stop turning on at all. some people have had success when "whacking" the side of the tv first...it seems silly but I've seen it actually work. It's only temporary though and that circuit will fail. If you have a great attachment to this tv, go get it fixed at the repair shop. If not, then just go get a new one. This happens to all types of tv's eventually.
Jul 03, 2012 | Sansui Televison & Video
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Rcr311w need help and advice on programming
WHAT BRAND OF TV ARE YOU TRYING TO PROGRAM
Jun 03, 2009 | RCA Universal Remote Control
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
