SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
SOURCE: McCulloch Steam Cleaner Problem
I have a similar problem but the light is not even coming on. This was a refurbished unit and the retailer sent a replacement so I can get into the broken one and see what's there.
Anyone have any ideas on how these work? Is it just off/on or are there saftey switches/fuses/breakers etc?
SOURCE: steam cleaner
There is something wrong with your Ladybug. I have the TidyVap, made by the same company...having problems with the water not being sucked down to the heater, not sure why...but I've been openin gup the bottom and adding water instead of putting the water in the top. I would get your steamer in to be looked at.
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
