You will need to have all of your setup information handy. Then connect a computer directly to the router. Press the reset button on the back of the unit to restore factory defaults. Type 192.168.0.1 in the browser address bar. The user name is Admin and the password is Password. You can then reset the settings including the security key for wireless access. The user guide can be found at http://kbserver.netgear.com/pdf/dg834g_dg834gb_ref_manual_03Jun05.pdf
Good Luck
430 is the catalytic convertor nearest to the radiator. but your problem is the other two codes are you using a copy key? they are the security codes anti theft. if the key is good not broken or damaged the if the theft system need to be fixed and reprogrammed.
This code is generally attributed to the DS not finding a connection to the internet using Wifi. The DS does not support WPA security. Change the security on your wireless router to WEP or No security.If you donot need the internet on your DS then change the internet wifi off. Another thing is to change the router to b/g or mixed mode. If you are using wireless N only then the DS cannot find and use the wireless network.
switch off phone then press *,3,call button and power on the phone(don't release the keys until the screen shows formatting)(it donot require security code).
THANK YOU
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.) 2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver) 3. Turn the ignition key to the ON position. 4. Press and release the emergency override button (The security system will turn off). Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger). 2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver) 3. Turn the ignition switch to the ON position. 4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1). 5. Within 5 seconds turn the ignition key OFF, then ON. 6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1). 7. Within 5 seconds turn the ignition key OFF, then ON. 8. If entered correctly the security system will turn off. 9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
It's a security feature by tryin to access your home comp you triggered your security , when you tryed to access it you may have input the wrong key code or security this may need to be reset when you reconnect , this can be done in control panel or right clik ya internet tab at bottom of tabs then right clik your connection then erase the network key an reinput the correct key . this should work as iv done it my-self once . hope it help's :)
