Question about Car Audio & Video
I have a 1999 dodge neon and i don't think it is playing burned CD's. do you think it was maybe a low quality CD?? or are those CD Players not supposed to from that year?? I really need to know because if not then I have to replace the whole effin deck.
  • 5,603 Answers
Some players won't play CD's that are not "finalized" or are the "Music CD" type. Try burning CD's that are "Music CD's" They cost more and are harder to find. If those work, then it is a problem with the feeble attempts at copy protection that was done years ago. No solution then other than to use Music CD's when copying and burning.
Posted on Jul 28, 2009
Cd player malfunction I have a 1999 gmc sierra that the cd player won't play my burned cds
Check other players to see if plays on any player. I had a computer once that kept defaulting to "data CD" no matter what I was burning, so I had to manually go to the setting and set it for "music".
May 11, 2014 | 1999 GMC Sierra
How much will it cost to replace the oil pump in a 2005 dodge neon
An oil pump for a Dodge Ram 2010 3500 cost: $111.20!!!
In this age of high gas prices, drivers who care about gas consumption are taking an interest in the Dodge Neon and buying top quality parts. When contemplating sturdy build and long lasting performance you want a stylish car from Dodge. For hardworking quality and styling from a vehicle, car lovers can believe in Dodge.
If an issue develops or a component needs to be replaced, don\'t economize with a second-rate part. A Dodge Neon is worth genuine OEM and aftermarket parts to function at top efficiency. When you wisely choose a trustworthy, historic Dodge, there\'s no doubt you\'ll get superb style. For decades Dodge has engineered heavy-duty and reliable cars that car buyers can count on to get the job done. For eye-catching style with tons of power car enthusiast turn to Dodge for their sporty vehicle needs. To maintain the resale value and luxury you bought with your Dodge Neon, it\'s important to select only the most reliable high-value car parts. Frugal people just need a sensible vehicle like the Dodge Neon. The Dodge Neon is a vehicle engineered for high performance and it requires the best quality auto parts. Excellent horsepower and automotive performance are derived from great parts and accessories.
The Dodge Neon Oil Pan is fitted to the bottom of the motor and encloses the sump which retains oil as well as the oil pump. Your Dodge Neon Oil Pan is used as a receptacle for the oil. Your vehicle\'s Dodge Neon Oil Pan retains oil in reserve and is frequently made from steel or aluminum and has an oil pan gasket to stop leaks. Your car or truck\'s Dodge Neon Oil Pan is bolted on the underside of the car or truck and supports the oil pump unit. Dodge Neon Oil Pans are important to lubrication and if they are old, your car\'s motor will definitely sustain damage. The Dodge in your carport was made using care and skill; it should have replacement components of the same high level of value. One website which makes finding affordable parts easy is PartsGeek.
18256-01144165-1085557.jpgThey are available for the following Dodge Neon years: 2005, 2004, 2003, 2002, 2001, 2000, 1999, 1998, 1997, 1996, 1995, 05, 04, 03, 02, 01, 00, 99, 98, 97, 96, 95. This part is also sometimes called Dodge Neon Engine Pan.
We stock these Oil Pan brands for the Dodge Neon: Mopar, Dorman and Replacement.
Nov 19, 2011 | 2005 Dodge Neon
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
May 10, 2011 | HP Computers & Internet
My 1999 neon ac compressor short cycles. has no cold air and also has a full charge.
Maybe there is too much refrigerant in the system where the high pressure cutoff switch invokes in short cycles.
Usually, low pressure in the system causes the short cycle/no cold air in the a/c system.
Sep 24, 2010 | 1999 Dodge Neon
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
CD takes too long to play or read
OEM cd players are set up to keep burned cds from playing well or at all. Some will work better if you use a better cd brand or quality cd.
May 29, 2010 | 1999 Honda Accord
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
What would cause discs burned recently on my Masterlink to not playback on others CD players?
Good day sir/ma'am hi, its a reality that not all CD players are alike, the burning of the CD which can't be read by other CD players can be caused by the following:
  1. quality of CDR and CDRW.
  2. lens compatibility.
  3. speed of writting and rewritting.
  4. scratches and marks on the CD.
  5. playback circuit that reads the CD.
  6. DIstance of the lens.
  7. manufacturers use different formats and methods of burning. and alot more.
For as long as the CD you burn on your masterlink can be played on itself, your fine. You can try burning the CD on the PC for more compatibility on the CD player.
Nov 09, 2009 | Alesis MasterLink ML-9600
1999 dodge neon 2door fireing order
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | 1999 Dodge Neon
How do u hook up a USB cord into the radio and my burned cd wont play is there a way to make it work?
well you can really just hook a USB cord into any cd player it has to come with one built into it already and if its not playing your burned cds then its probly of low quality or old. or it doesnt recognize the format that you are burning the cds with especially if your using windows media player to durn the cds some cd players dont read WMA files (windows media assotiated) files
May 06, 2009 | Kenwood KDC-X890 CD Player
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
