Question about Nintendo Wii Console
Wii remote doesn't come on. Blue lights don't
Wii remote doesn't come on. Blue lights don't flash
  • 952 Answers
Thanks for using FixYa!
If the blue light on your Wii controller doesn't light up, its possible that it ran out of battery charge. If you think your battery is fully charged. try to buy a set of disposable battery and see if they will work. If they do work, it means your rechargeable batteries have gone bad.
Have a great day.
-HotRatchet
Posted on Jul 28, 2009
4 Suggested Answers
LesPix
  • 5 Answers
SOURCE: wii remote
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
LesPix
Posted on Feb 29, 2008
  • 15 Answers
SOURCE: reprogramming wii remote
Okay, on the front of the wii open the door where you'd put in an SD card, and take the battery covers off the remotes so you can access the reset buttons on both the console and remotes. Then press the red reset button on the wii and then within a second or two press the ones on the remotes. This should connect your remotes to your wii.
Posted on Mar 18, 2009
FFPro
  • 66 Answers
SOURCE: wii remote
Try to register the Wii controller because you need to register the controller.. or else you cant play with the wii unless you use the 1st controller they give you its already registered to the wii so if you want to use more wii controllers and you buy more you have to register 1st before playing any games at all.
Posted on Jun 21, 2008
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
The control lights of my wii just keep flashing but the controls don't do nothing to the wii, I try new bateries and still don't work
First, remove the battery cover for the Wii Remote
Then open the small panel on the front of your Wii console
While holding down the sync button on the controller, press the sync button located under the small panel on the console, wait a moment, your contoller should then be synced.
Jul 22, 2011 | Nintendo Wii Remote Controller
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
My wii remotes switch on and all four lights flash blue for about 30 sec then nothing! Any ideas?
You might want to sync your remotes to your Wii hit thhe sync button under the battery coner on the remote and under the wii special compartment
Apr 12, 2010 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Wii remote will not turn on and the blue lights either
all you have to do is open the place where you put an sd card on your wii then open the battery cover on the wii remote and press the SYNC buttons at the same time and it WILL TURN ON trust me it works
Jun 26, 2009 | Nintendo Wii Console
My Wii Remote Won't turn on!
1) Make sure there are good batteries in it.
2) Make sure that the batteries are in it correctly.
Otherwise, there should be no reason to get no blue light - even not being sync'd properly wouldn't result in no light. May have to fess up to Mom. :X
May 07, 2009 | Nintendo Wii Remote Controller
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Remote
The problem where the lights would flash on and then go off happened to me also.
I pressed the 'sync' button on the wii remote and the red 'sync' button on the console at the same time for about 10 seconds. Let go of the buttons and then the lights should flash and light 1 on the remote came up!!!
Hope it works for all 'ya!
andy
Jun 06, 2008 | Nintendo Wii Console
Wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,066 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
