Question about Car Audio & Video
My eclipse radio volume knob is broken, can I fix it or do I need to send it in. I don't want to spend the $120 to repair it.
  • 37 Answers
You will need to send it in other wise you will have to try and find one to install yourself
Posted on Aug 05, 2009
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
I have a Lexus es300, year 1993, the radio's volume control broke off, is there any way to fix it??
If it is a knob and you have the pieces, crazy glu will do it. If not you will have to get it replaced.
Mar 16, 2013 | Lexus 1993 ES300 Radio a1z101720 receiver,...
THE OFF AND ON KNOB IS NOT WORKING PROPERLY ON XTN RADIO, HOW DO I FIX?
The on/off/volume potentiometer is a common failure part on most radios, including the XTN. The only solution is to have the radio repaired. Typically this style unit can be repaired for $69 flat rate.
Sidenote: On the XTN it is best, when turning on the radio, to turn the knob to at least 50% volume before turning it back to your desired setting. This helps with the initialization of the radio. Also, it is best not to run this style of radio at full volume, as it can cause other receive issues down the line.
Best regards.
Sep 22, 2010 | Motorola XTN 2-Way Radio
I Have a Radio Shack Pro 95, thats loud or freaking loud.
Could be that you wore out the volume knob, or may have turned it too far in either direction. If its the knob itself then depending on your experience working on electronic equipment and the ability to get a replacement knob you can maybe fix it yourself or may have to send it into Radio Shack for them to repair it.
If the knob turns real easy you probably have a worn out knob.
Jun 05, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I fix the volume switch/knob? (CY290)
Take the radio out then take apart radio and clean volume potentiometer with electrical cleaner from radio shack. Or just change out radio.
Mar 04, 2010 | 2001 Nissan Sentra
2005 trailblazer, how do you remove the radio volume know
You should be able to pull the knob out straight. If the knob is broken then you should be able to use a small dental pick to get the piece out of the radio.
Roy
Aug 11, 2009 | 2005 Chevrolet TrailBlazer
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
Eclipse 5440 head unit locked
There is another solution to the radio being locked up you can try,,, If you look REALLY hard under the volume knob of your radio on the front there is a VERY small reset button. This worked for me last time, if this doesnt work then try calling them. If there originally was NO code number entered than this will work. Good luck, let me know how it turns out.
Feb 23, 2009 | Eclipse 5440
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
Car Audio & Video Logo
288 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
