Question about GE Refrigerators
Evap. blower motor not running.
Hotpoint HSS25IFMDWW evap. motor not running. I replaced the motor but still no movement. The lower food section freezes but the upper shelves are warm.
George
  • godaniel51 Jul 29, 2009
    That took care of the problem:) Thanks
  • GE Master
  • 1,606 Answers
You have a bad main control board . Usually on HSS models , when one of the fans don't work , its due to burnt resistors on the board (not the motor) . only way to fix , is replace the board .Patr # WR55X10656
Posted on Jul 28, 2009
2003 saturn L200 blower motor will not run
Could be your blower motor resistor,it's next to the blower motor,2 screws hold it on,here's a picture of it. Blower Motor Resistor at AutoZone com Best Blower Motor Resistor Parts for...
Sep 26, 2015 | Saturn Cars & Trucks
We have a Hotpoint Side by side- Freezer is working but the Refrigerator is not getting cold - What to do??
There is a couple of things that could be going on here.
1. Open you freezer door look at the back panel and see if it is covered in ice. If it is you most likely have a defrost issue. If this is the case the Evap coil becomes covered in ice to the point it does not allow any air flow.
2. Open freezer door and with one hand push in the door switch so the light goes off. Listen and feel to see if the Evap fan motor is running. If it is not running we could have a bad fan or a bad board.
3. Open you fridge door, in the top left portion of the should be a damper assy. put your hand in front of this damper and fee for cold air and some air movement.
After you have done these three things I walk you a little further in solving your proble,
Sep 01, 2011 | Hotpoint Refrigerators
Where do I find the model number on my Hotpoint
In the last few years GE has placed the models serial label on the top center, top left or top right of the fresh food section. Older models had it behind the fresh food door at the bottom or behind the grille. Also there were a couple of years they placed it behind or to the side of one of the lower drawers.
Sorry about all the different locations. That's just how they did it.
Thanks.
May 25, 2010 | GE Hotpoint Top-Freezer Refrigerator
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
FRIDGE NOT COLD FREEZER WORKS FINE
Make sure the freezer fan motor is running. Remove the rear panel in the freezer and check for frozen coils. If coils are frozen replace the defrost heater and thermostat.
Check the air vents to the fresh food section,are they frozen closed?
Jul 17, 2009 | Hotpoint HTS16HBMWW / HTS16HBMAA Top...
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Freezer leaks into lower section
there is a drain pipe that goes to the bottom of the fridge . push a flexible hose down it to unblock it , it is for the auto defrost .
Apr 01, 2009 | Hotpoint  17.2 Cu. Ft. Top-Freezer...
Left not transfering cold enough air to right side. doesn't get colder than 50 degrees, why?
Remove back panel of freezer (where you see the frost) and melt the frost with a hair blower. The frost blocked evaporator coils are not allowing air to pass over the cold coils, so no cold air is able to get to the fresh foods section. You will most likely need to replace the defrost heater at the bottom of the evap coils to prevent this from reoccurring in two weeks time.
Nov 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
204 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
