Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
Has stripes going down it when scanning or faxing this to paper or pc and ect is it light or deeper thing Lexmark X5150 aio Lexmark X5150 aio Lexmark X5150 aio
Lift the cover where you place originals to scan / fax, and clean the narrow scanner glass underneath. There are simply some specs of dirt that when the original is scanned across them, they show up as lines
Posted on Jul 28, 2009
How do i fax with my lexmark X5150
Make sure the Fax software or Lexmark All-in-One software is already installed in your computer. The printer should be connected to a computer with a fax modem. Here's the link to download the Lexmark X5150 User's Guide: http://bit.ly/aSItHD. Scroll to Page 26 for the instructions on how to send a fax. Hope this helps.
Jul 20, 2010 | Lexmark X5150 All-In-One InkJet Printer
Fax machine
Scan platform is located above paper cover. Its like long rectangle with wite stripe and scaner. In some cases it falls down and the documents from feeder cant came trough.
Push it up back, and should work.
If doesnt works, you have bad main pcb fault.
Jul 14, 2010 | Canon FAX L-120 Plain Paper Laser
I cant get my lexmark x5150 to scan to a file. what do i do?
Hi, I will try the following, Uninstall completely all the Lexmark software as well as the printer driver. Then go the Lexmark website and download the latest driver. That takes care of this issue most of the times.
Feb 04, 2010 | Lexmark X5150 All-In-One InkJet Printer
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do I connect my X6150 to my PC just to scan pictures into the computer
I believe that the AIO Lexmark printers connected to the PC via the USB port on the PC.
They also may have connected by a parallel port connection using the ECP connection protocol of the IEEE 1284 Standard.
Don
Dec 09, 2009 | Lexmark X5150 All-In-One InkJet Printer
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off the AIO and remove the power supply from the back of the unit.
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark AIO X5150 printer powers off just before printing
Hi, I would suggest you update your printer driver, try this, follow instructions exactly as written, do not use installation cd:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 21, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 3550
Go to :http://downloads.lexmark.com, and see if there is an updated DRIVER PACKAGE or UPDATE PATCH you can download. If not, contact LEXMARK TECHNICAL SUPPORT, and they can help you resolve this issue.
Aug 21, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 paper feed problem
the rollers may be dirty or there is a small piece of paper stuck down in one of the tracks or channels..
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
