Question about Garden
Cable I have a yard machines walk behind mower with a tecumseh engine that is only a year old. The cable that goes from the handle down to the engine won't pull the lever enough to allow the engine to start. Is there any way to adjust either the cable or the lever?
    President:
  • 1,776 Answers
I'll tell you what I did to a cable like that on an old mower of mine, if you promise not to laugh at an old ****. I cut my cable shorter and fashioned a little bushing out of some small weedeater fuel line, so the edge of the hole on the lever wouldn't wear on the cable, and crimped a small cable clamp in the position I wanted and was back in action. Hope this helped, don't laugh, and best wishes.
Posted on Jul 28, 2009
  • Bruce Canfield
    Bruce Canfield Jul 28, 2009
    In all seriousness, I did do that. But, what is the problem with your cable, does it seem too long? Look where the the cable is secured on the mower with the clamp, loosen it, and adjust the cable casing where you want it to put adequate pull on the lever and tighten down. Hope this helps and best wishes.
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have MTD Yard machine and don't know if it is 2 or 4 cycle. Oil should be-SAE30. Can I use oil for 4-cycle which they soid me i Can. Tire.(M otomaster)
If your mower has seperate fill caps for the oil and the gasoline, then you have a 4 cycle or 4 stroke engine. In this case use SAE HD30 motor oil. If there is only 1 fill cap and it says oil & fuel mix, then you have a 2 cycle or 2 stroke engine.
Good luck
Sep 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
What is the cable on a yard machine walk behind that stops the motor when you releace it called.
The dead man cable or "deadman bar".
It kills the power to the magneto and stalls/shuts down the engine.
Jun 21, 2010 | Garden
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
There does not seem to be a spark. I even put fuel
is the deadmans handle pulling the cable enough to cancel the off switch? if not relase the cable from the handle, TIE A KNOT IN IT(!), re fit to handle, & bingo!
If the cable is working well enough already DONT tie a knot, it wont help, its the ignition coil! ( around £30)
Apr 02, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Suddenly stopped then could not pull mower backwards because rear wheels would only go forwards, and mower would no longer start
Sounds like your mower has a safety mechanism that has locked up. On your push handle is a bar that must be pulled back in order to pull start cord, it has a cable that goes to the safety brake, check the cable to the safety brake on the flywheel, it may be broke. If it isn't in the safety brake itself, try spraying the cable with WD-40 as this may free it up. Or the cable may need replacing from wear. To check this pull back on the handle and watch the on the side of the engine where this cable attaches, if it is moving on the side of the engine then this cable won't be the problem. In this case it most likely will be the safety brake itself that's the problem. Do not remove the safety brake if under warranty as this will void your warranty.
Aug 08, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
