Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag MZD2665HES has stopped making ice.
Not sure the culprit - it was slow making ice for a bit, then just went on strike completely. I removed the water filter completely thinking perhaps there was a blockage, put in the bypass for filter and still no ice.
5 Suggested Answers
SOURCE: Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
Posted on Sep 01, 2007
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Posted on Feb 07, 2009
  • 2976 Answers
SOURCE: Water flow on my Maytag ICE20 is very slow.
The orifice into the filter is getting clogged. A toothpick or small paperclip will clear it.
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: Our Maytag icemaker stopped making ice suddenly
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Posted on Aug 20, 2009
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
May 25, 2013 | Maytag 26 cu. ft. Wide-By-Side...
I have a ICE2O maytag refrigerator that is 2 years old my electricial board was bad and I had it replaced. The part number is 1290710. Now my ice maker does not work. I have water but no ice. I have...
f there There's no ice Please read this entirely to assist you in troubleshooting this problem. If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If too cold then the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 01, 2010 | Maytag Refrigerator Icemaker Ice Maker...
Hello there:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Aug 07, 2010 | Maytag Freezers
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus Side/Side slow loss of cooling to the Fridge side
sounds like your having a defrosting issue. you either have a bad defrost controller, or a bad heater/ defrost themostat.defrost controller more often the culprit
Mar 16, 2008 | Refrigerators
My 9 month side by side refrigerator
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
226 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
