Have a dell 1525 that wont come out of hibernation. Already tried using the ''hold power button for 5 secs'' and removing the battery options. Any other suggestions?
  • 125 Answers
If you removed the battery and power cord and it did not reboot tyhen it is not in hibernation try hooking up an exterior monitor and see if it comes on when you boot up if not it is either the video chip or the mobo
Posted on Jul 28, 2009
Hibernation permanently
Yep, pull the plug. Power Cord, remove the battery, then press the Power Button and hold it for 15 seconds.
Next time you boot up go into the Control Panel and check your Power Options. You can set it to never hibernate.
Apr 02, 2012 | Dell Inspiron 1545 Notebook
My Dell Inspiron 1525 is stuck in "hybernation." It will not let me "control, alt, delete" and I've even tried removing and reinstalling the battery. Help! Thank you!
Press and hold down the power button until the computer shuts off. Then wait at least ten seconds and power it back on.
While it is booting up and you see the Dell logo on the screen, press and hold the F8 button. When the next screen appears, you will see a list of options for how you would like to continue the boot up process. Highlight the option titled "last known good configuration" and press enter. Your computer will restart and load up with all of the settings previously used before it began giving you problems.
Apr 23, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 when starting it says resuming windows then goes to hibernating with a little blue curser going around
Turn the computer off, remove the battery, make sure it is not plugged in to power, and hold the power button down for 10 seconds. Wait about a minute before re-installing the battery. If it does it again, hold F10 while the computer is turning on, this should bring you to the "boot select" menu, use the arrows on the keyboard and select "start windows normally" instead of "resume windows". When you get it started up run "Defrag" to prevent this from happening again.
When windows hibernates it saves everything in the ram to a "swap file" on the hard disc. Sometimes hard disc's get "bad sectors", this is considered wear and tear, it happens eventually to all drives. It sounds like there is a bad sector on your disc where the swap file is stored, so you have to start windows without using that part of the disc, then by running defrag the computer will find the bad sector and remember not to use it anymore.
Have a nice day.
Jul 24, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
It's in hiberation mode , how do I get it out of hiberation, it's a dell inspiron laptop.
When you power up the computer press F8 key then enter in safe mode.
then go to control panel -> Power option -> Hibernate
then disable check box hibernate Also check power scheme it is first tab in power option
Set "Turn off monitor 20 minute"
then apply and ok then restart the computer.
Thanks for using fixya
Please rate my solution if it helps.
Jul 21, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1525 touchpad not working properly
You can try the following steps.
1. Turn laptop off.
2. Remove all external devices and disconnect AC adapter power cable from the system.
3. Remove the battery from the system.
4.Hold down the power button continuously for at least 5 seconds. Do not release the power button during this process.
5.Insert the battery back to the system.
6.Power the laptop back on.
Try using touchpad again.
Dec 29, 2008 | Dell Inspiron 1525 Laptop Jet Black
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
