Question about Canon Pixma iP6000D InkJet Photo Printer
Printer jamming when printing in color
We replaced the Photo Magenta and Photo Cyan. The printer works just fine when we print black and white now, but it will jam and make an awful sound when we try to print anyting with color. We've replaced several cartriges before and everything was fine. Don't know what's going on now. Tried making sure each cartridge is in, made sure we installed it right. Thoughts?
  • 4,402 Answers
Make sure the color cart. are installed correctly
Posted on Jan 15, 2008
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
50 people viewed this question
old marine
old marine
