The vents on my AC is Leaking Water
Is the A/C Fixable?
    President:
  • 986 Answers
Sounds like your evaperator is not draineing, does this happen on day when you area has more humity?than others what part of the country do you live in,(example if you live in phiniox you should not have a big problem,
Posted on Jul 28, 2009
    Champion:
  • 363 Answers
First Question? are the branch lines that lead to your registars insulated. Are the branch lines that go to your registars flex line. If the branch lines are not insulated, condensation forms because the cool air and the hot air meet at the uninsulated branches which drip condensation(water) from your registars
Water is leaking from the floor vents what could be the proble?
Check your heater radiator. It is usually mounted behind/near the glove box areas on most cars. It is like a small version of the large radiator that is mounted on the front of your vehicle under the hood. Antifreeze and coolant (does it smell a little like antifreeze?) flows thru your front radiator, thru the block and hoses, and cycles thru the radiator for your heating system. If the radiator is leaking, often it cycles thru the vents on the interior.
Another possibility MIGHT be the AC system and condensation/AC coolant that is building up in/on the lines and transferring thru the vents.
Aug 18, 2014 | 1999 Buick LeSabre
Hummer ac problem
vent control mechanisn may not be working , as have had water leak may have damaged the direction control switch so i'd strip out the heater control panel and check the connector for the direction control
May 10, 2014 | 2005 Hummer H2
Water is leaking from the ac vent in the inside of our rv. We took the cover off and it looks like water is leaking from some kind of hole in a silver box. How do you fix this?
Water is NORMAL in the process of A/C, works like glass of icewater, water vapor condenses when chilled...This condenced water should be drained outside, usually by a black drain hose. you cannot block the water or the system will fail, smell bad, and damage the evaporator (similar in function to a heater core, but for AC).
Oct 15, 2010 | Dometic Rooftop RV Air Conditioner
My 1993 dodge dakota sports is leaking water into the cab on the passenger side its not threw the air vents and my ac fuse blows out evertime it happens
The only way water can get into the cab is either a blocked air vent drain, leaking windscreen seal or rubber, damaged panel joint, badly sealing wiper arm. badly sealing door. Try and follow a possible trail. Water will move great distances before dropping so the leak could be far from the results.
Feb 26, 2010 | 1993 Dodge Dakota
A lot of Water leaking on driver side floor --
It is possible that the ac drain is clogged blowing some compressed air can clear it and allow water to flow again it is also possible the ac box may be leaking
Jul 28, 2009 | Lexus ES 350 Cars & Trucks
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Leaking water from ptc ac unit in front .vents all open
make sure unit is has slight fall toward outside.
Jun 15, 2009 | APC Heating & Cooling
Water is leaking from my downstairs air conditioning vent
I seriously doubt it's the AC. It may be the draing in the upstairs shower, If it's a water line it is a very small leak and is probably puddling in you ceiling. if not nbeing absorbed. Best thing is contact your homeowners insurance because you are going to not only have a plumber to deal with , but a mols issue as well. Sorry, good luck.
May 31, 2009 | Heating & Cooling
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Water from atr conditioner leaking in on floor
make sure the drain tube for the box is not clogged in the engine compartment firewall left side the AC condinsor has to bleed off water because of condensation on it from being in use,, otherwise u would have water with anti-freeze from the heater core if it was leaking ! but just water its the AC condinsor, lot of junk gets in the box from the vents and sometimes cases blockage
Aug 03, 2008 | 1997 Chevrolet Venture
Heating & Cooling Logo
227 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
