Question about Dishwashers
We have a Bosch dishwasher model SHU5315UC/U06. When we ran a "Regular Wash" the dishwasher ran continuously and the timer did not count-down. None of the Delicate or Rinse and Hold buttons responded. The only button that works is the "Scrub Wash", but when we ran it did the same thing. Ran continuously and the timer moved one minute after running about five minutes. I look forward to your solution. Thank you. Jerry
  • 11 Answers
My father-in-law has a Bosch and they had the same problem. The tech guy said it was not heating properly and that caused it to continously run because it won't tick down the timer if it doesn't reach a certain temp, so try turning your faucet as hot as you can, right before you turn on the dishwasher and see if that is the problem, if not the heating element might not be working properly. If you still have a warranty, try to get them to see and fix it, otherwise, get a repairman to check it out. You can also turn up your hot water heater, but not so hot it would be dangerous to use, but enough to get the temp up. Otherwise the heating element might need to be replaced.
Posted on Jul 28, 2009
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Will turn and show count down numbers on any cycle,but thats it will not continue.
Might be stuck in a diagnostic cycle. Have you turned the power off and back on?
Press and hold "Regular Wash" & "Power
Scrub Plus
" buttons. See if it makes any difference.
Please post a comment to confirm how it is going.
Nov 04, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a model SHE 44 C05 UC/40. It is three years old. It starts up fine, fills with water and goes into the wash cycle. Then it continues to wash indefinitely, even though the electronic timer display...
Sounds like the heating element. It may be waiting for the water to hit temperature before moving on to the next sequence. Test the element for continuity
Jan 03, 2018 | Bosch Dishwashers
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
Dishwasher stalls
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Apr 07, 2009 | Bosch SHU4006 Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
232 people viewed this question
Top Dishwashers Experts
