Question about RCA HD52W59 HDTV Projection Television
Tv wont converge
Looks like 3 d photo, just replaced the board , what can it be??
Hi i have a convergence problem bought tv 5 years ago 2 techs have looked at it and have replaced convergence sensor unit and digital convergence unit but now tech says i need a convergence board and not...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2010 | Toshiba 51H83 51" Rear Projection...
My screen convergence is not working. When trying to get to screen convergence mode, it has disappeared and no longer available. Guessing a circuit board went. Is there a manual means to adjust?
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Oct 10, 2009 | RCA P52926 52" Rear Projection Television
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
48 jvc
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Jan 31, 2009 | JVC AV-48WP30 48" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Hitachi 51F510 Convergence Problem Solution???
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Dec 09, 2008 | Hitachi 51F500 51" Rear Projection...
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red Convergence out on right side of the screen only
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Dec 08, 2008 | Samsung HCM4215W 42" Rear Projection...
Warped picture Toshiba 65HDX82
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Mitsubishi VS-50501A convergence problem
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
