Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
GE side by side refrigerator
The center frame and sides are hot to the touch
  • 1 more comment
  • Anonymous Jun 23, 2008
    the body and sides are hot to touch
  • Margaret Zoltek Jan 22, 2009
    Have a HOTPOINT HSS25IFMDCC side by side fridge. Fan blades do not turn. Vacuumed/cleaned back compressor, fan, etc. Had a guy come out & he tried to replace the fan motor-but the blade still wouldn't turn. I have a FAN blowing on the compressor to minimize additional problems-any suggestions on how to fix the fan, or what might be wrong?
    Thanks!
  • Margaret Zoltek May 11, 2010
    Hi Amigaman-
    Thanks for the FAST reply! I tried ALL of that. Even had a repairman come out to replace the fan motor. When he plugged in the NEW fan-the blades still didn't turn. Nothing was stuck in the fan blades-as they are turning because I have a table fan blowing on the compressor.
    Its a HotPoint Side by Side Model #HSS25IFMDCC
    Thanks Again!
  • 248 Answers
Try pulling toe plate at bottom front and clean the condenser coils. If they are plugged, it will cause this to get hot. If you can't see coils in front remove back panel and clean coils there.. Give it time after cleaning to see if it helped. If no change, remove back panel and check to see if fan is turning when the compressor is on.
Also check for something caught in fan blade, such as a dead mouse or a dead coupon. If fan isn't turning, may need condenser fan motor. If still need help, give us a model number. Found in refrigerator compartment at top on side walls.
Posted on Nov 22, 2007
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
My fridge is working but to touch the outside it is extremely hot to the touch. What would be wrong with it?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 07, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The center post of my refrigerator side by side where both dooes meet and close on is warm to the touch.
heatman101
May 19, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
Center support of Side By Side is Hot to the touch
Hi, welcome to Fixya. The heat between the doors is normal and done by design to help prevent moisture along the "breaker strip"/divider. If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about. Just be sure the condensor fan isn't jammed and still turning. If not turning it can cause the unit to become extremely hot. The amount of heat can and is determined by several factor's such as, temperature setting - lower/colder the temperature is set the more the run time the hotter the strip. The ambient temperature - hotter the environment the more the unit runs the hotter the strip. The amount of "fresh" content added to the unit - new items add a lot of warmth thus demanding the unit to run more to remove this heat causing the strip to be hotter. Build up of dust & dirt on the condensor coils ( they should be vacuumed annually ) - this also causes the unit to run excessively which in turn makes for more heat on this strip. These are all things which can and do determine the amount of heat between the doors. If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned. Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward. Please take a second to rate the info provided here. Macmarkus :)
Jun 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
172 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
