Question about GE DBXR463EBWW Electric Dryer
Loud Grinding Noise when Tumbler Rotates
Does the tumbler have replaceable guides or owner maintainable components that would address a loud grinding sound when the tumbler rotates? If so, how do you disassemble the housing to get the tumbler out for maintenance?
Thanks
  • Anonymous Mar 14, 2014
    Dryer is making a loud grinding noise every few rotations. No set amount of times, very loud
  • 240 Answers
Ok, these GE's sometimes have a problem with the front guides bearings going bad, and then the drum starts to eat into the top of the door hole and sides. That is probably what is making your noise. Before you spend a lot of time fixing something that cant be fixed, open the dryer door and look up in each top corner of the opening. Look to be sure the drum hasnt eaten its way through that area. If so, scrap it, because it will eat your clothes badly, and the front panels are to expensive. If not, UNPLUG YOUR MACHINE PLEASE, then standing facing the dryer, open the door, and remove the two screws that are in the top of the door housing area (not the door itself, these would be up by where I told you to look for damage). These screws hold down the top. After removing these screws, lift up on the cabinet top, and pull GENTLY towards you until the top clears the console guide posts in the top rear. After removing the top, inside the cabinet, on either side and at the top, you will see a phillips head screw that holds the front to the cabinet. Remove these screws, and fold the front towards you slowly, removing any wires that may be holding up the swing out (i.e. door switch, light wires, etc., be sure you remember the way the wires reattach). When you look at the top of where the drum rides, you will see a plastic ring with smaller like plastic flat peices that the drum rides in. More than likely, you will have to replace both parts. The ring separates in the center, and is replacable (you should only have to replace the top half). The drum guides are the smaller plastic type guides that just slide in. Reassembly is reverse. Let me know if you need further help. Jim
Posted on Nov 22, 2007
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
Sounds like the tumbler is goinfg out , very loud
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 30, 2010 | Amana DLE330RAW Electric Dryer
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
He dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Apr 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
We have a penny stuck under the white spinning things.
Hello pinkygirll,
The Service manual has the procedure starting on page 37 for the tumbler removal, take a look and see if you feel comfortable to give it a try. If you are handy or someone you know has basic mech. skill sets you can perform. You, I and many others need to check those pockets. Here is the service manual link.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The manual doesn’t call out the torx driver size required for tumbler removal. I just removed my tumbler cap and measured, it’s a #20 torx driver. If you call a repair service in make sure you have your Model# and Serial# number ready to pass along to them. You mentioned”” There is a penny stuck and the washer stops with water in it after it tries to spin.”” The tumblers do not rotate in spin cycle only the wash cycle. If you do a Spin Only cycle with no clothes in the wash basket do you hear the grinding noise? Good Luck.
Mar 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
GE DBXR463EBWW Electric Dryer Logo
203 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
