Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Washer stopped working
We've got model WSM2700AWWW combo and the other day my wife complained about the humid heat air. So I pulled out the unit, got behind there and put the air vent back where it should be. Put the unit back, and thought all was good. Today, my wife said the washer isn't working, it filled with water (she had left the top open) - and then when shutting the lid, NOTHING happens. I've taken most all of the water out and also the clothes, but still nothing. Reset circuit breaker (but dryer works, so obviously not that). Hope you can help me out please ...
gittos73
  • 244 Answers
SOURCE: PLEASE HELP!
right could be your belt,casrbon brushes if the motor has these which you will notice they will have a wire going to a small plastic part on either side of your motor it will have 2 of these if these are worn down to about 8ml they need replacing if your washer does not have carbon brushes than it will have a small circuit board called a module if this is faulty sometimes cheaper to replace your washer
Posted on Aug 14, 2007
SOURCE: New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
Posted on May 29, 2009
  • 512 Answers
SOURCE: I have a Top Load GE Model #WBSR3140G1WW. The
This is an electronic washer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly. This will reset electronic motor.
Posted on Jul 18, 2009
SOURCE: Washer wont drain....
try the lid switch with a screwdriver in the slot to see if it activates. Mine did the same thing, would agitate but not empty nor spin and it was the lid switch assembly--a 35.00 part that cost 150.00 to repair with a repairman!
Posted on Sep 04, 2009
  • 14 Answers
SOURCE: GE Spacemaker Washer/Dryer wont start only washer or only dryer
check power from the out let make sure they got 220 v
Posted on Mar 03, 2010
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
My Danby DPAC1010 Portable Air Conditioner is dehumidifying when simply in AC mode. I don't want it to, but if fills up a 2 gallon bucket every 2-3 days. I've had it overflow twice and I cannot...
The only way to stop it from dehumidifying is to stop it. A dehumidifier is a AC that is 'tuned poorly'. In your machine, while in dehumidify mode, you actually are running the AC in 'slow".
It is a law of physics. Warm air can hold moisture. Cold air can not hold moisture. When you remove the heat from the air, the water has to go somewhere, so it condenses on the coils and drips into the tank. Yes, that is true: Heat is a thing, you have to remove heat from the air. You don't simply "cool it", you remove the heat.
Your Danby should have a automatic shut off that comes into play when the condensate tank gets full. MY Danby, which is a sllightly different model than yours, has a connection that allows me to connect a hose that I lead to a floor drain to disponse of the condensate (water).
If yours is not equipped with a shut off nor a drain and you say it fills every 2 to 3 days, the options I see that you have is to dump it every day, or - don't run it all the time, or - turn the setting to a higher number which will reduce the AC and dehumidifying effect. On the down side of that, your humidity will remain high at the higher setting.
Thanks for your question @ FixYa.com and thanks for letting me assist you this evening.
Jun 29, 2011 | Heating & Cooling
I just bought a LG Model LD650AL two days ago from Home Depot. My question is when I hooked it up and started it, it ran for awhile (15mins) then it stopped. Seems to me that it a quite warm behind the...
If you just plugged it in and started it up, you may have failed to set the humidity extraction level. Which is different from the factory settings. If you want to remove great deal of humidity, lower the setting to 35%. Keep in mind, the lower the setting the more humidity/moisture will be removed from the household air. The higher the setting less will be removed.
As far as the unit beiing warm is concerned ... Be sure to maintain at least a minimum of 12" clear air space all around the unit while in operation. Do not operate the dehumidifier in direct sun light.
Also, make sure all the packing material has been removed from the interior of the unit. This will block the airflow and cause the unit to overheat. If it does overheat, it should shutoff automatically. But, don't confuse that with normal automatic shutoff (i.e water collection bucket full, timed cycle has ended, no more humidity to remove from the air, etc.)
When all else fails, consult the owner's Manual.
Hope this helped you. Please let me know.
Jun 06, 2011 | LG Dehumidifiers
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
Promac wall unit Model # PS9OCR. Unit was left on
I would suggest you check how humid it is outisde, if it is really humid it is pulling water out of the air, the drain could be plugged also. And the filter could be plugged or the condensor may be defective or plugged.
Aug 28, 2009 | Heating & Cooling
Mitsubishi Through the Wall Unit Does Not Remove Humidity
You were told incorectly. From what you are describing the unit is oversized for your space.
All Air conditioners remove humidity. In fact the Air conditioner was invented by accedent by Mr carrier when he was trying to invent a machine to remove humidity. He discovered that by drawing air accross a cold coil the humidity drained off the coil. He also discovered that it was a mighty effective way to cool large quantities of air, and we then had "Carrier" air conditioning systems.
When a system is to large for the area it is to cool, it will cool the air in that small area so fast that the humidity starts to condense in the room before it can be pulled through the evaprator coil.
In this case, the solution would to be either replace the unit with a smaller one.
Increase the area to be cooled. (open doors to other rooms etc). or use the dehumidifier.
How many square foot is the space you are trying to cool?
What size is the AC unit? (in "tons")
Aug 25, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Does not drain all of water out unless you raise the lid during spin cycle
This is sometimes the coupler, sometimes timer has shorted out.
Sep 22, 2008 | Kenmore 23822 Top Load Washer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
